General Electric GE 24-Hour Power Strip Timer #57698 Logo
Posted on Dec 15, 2010
I need instuctions on how to use the GE 24-Hour Eight-Outlet Digital Strip Timer (Black) i have lost mine.
Gene Lyday
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 12, 2014
Gene Lyday
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1371
Points
Http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15077-Manual-eng.pdf
A
Anonymous
See both GE strip timers to identify product:
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
GE 15077 digital or programmable strip timer manual
http://waterheatertimer.org/pdf/GE-15077-Manual-eng.pdf
If this manual does not match your timer, add a comment.
Timer GE15119 should the lamp be on when you plug the timer into the wall outlet ?
It is a very basic mechanical timer. I have 3 of them.
Remove it from the wall.
Pull the tabs up for Off and Push tabs down for On.
Set the Time by turning the dial, time to arrow.
Set the slide switch to Timer On.
Plug in the appliance.
Plug the timer into the wall socket.
Manual and Advertising is here.
GE 15119 Manual - Waterheatertimer.org
http://waterheatertimer.org > pdf > GE15119-Man...
PDF GE 15119 timer manual http://waterheatertimer.org/How-to-set-timers.html http://waterheatertimer.org/GE-timers-and-manuals.html#52012.
GE 15119 Indoor 24-Hour One-Outlet Plug-in Basic Timer ...
https://www.toolboxsupply.com > products > ge-15119...
GE Indoor 24-Hour Mechanical Timer is an easy-to-use basic timer. Ideal for lamps, seasonal lights and portable fans. Turns a lamp on/off at desired times daily, ...
How to use a Defiant brand pin timer?
Yes you can use it with a power strip.
The lamp switch should be left in the on position, the timer will turn the power on or of for the power strip.
Also make sure the power switch of the power strip is in the on position also.
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Need instructions to set time for 8 outlet power Strip timer Utilitech
Copy following link to identify power strip timer:
Zilla, Utilitec, GE strip timers use basically the same format for programming.
For each ON time, there has to be a corresponding OFF time, and days for On and Off times cannot conflict.
Best guess: you have a conflict or incomplete on-off program.
With Zilla timer, there is added level of complexity since the ON-OFFs are set for different day and night outlets.
Add a comment with the exact timer model number so expert can read the manual alongside you.
1helpful
My power strip, that I paid good money for about 7 years ago, is now vibrating and making a noise during the night time. Obviously, this is when it is not in use and does not seem to have the problem...
Question posted under analog power strip.
Analog timer has small clock motor.
When the plastic motor gears wear down, the clock begins to make noise.
Might not hear the noise when TV is turned on.
To get analog timers to last longer, be sure to keep timer in dust-free environment so nothing clogs the gears.
I don't know how to take apart this timer without breaking it.
New GE timer at Amazon $10.46
http://www.amazon.com/57698-24-Hour-Power-Strip-Timer/dp/B00067OOFY/ref=sr_1_1?ie=UTF8&qid=1292413124&sr=8-1
Heavier duty Woods timer at Amazon $19.62
http://www.amazon.com/Woods-22575-24-Hour-Power-8-Outlets/dp/B002L706K4
Buy Utilitec power strip timer locally at Lowes and save shipping.
Buy GE at Home Depot and save shipping.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Have set the timer to come on at the same time every day and off at the same time every day but when I put it Auto mode does not turn on. What step am I missing
You posted under GE dial-type power strip timer.
GE has 2 different models: 57698 & 15090
15090 has instruction manual, and 57698 doesn't.
http://waterheatertimer.org/GE-timers-and-manuals.html#57698
GE also makes 15077 digital power strip timer:
The digital power strip has Auto mode.
1) If programming has overlaps, or if programs are set for conflicting days, then timer will not operate as expected. Review programming steps by pressing PROG button.
2) If current time is not set, then programs will not operate. Press and HOLD clock button while setting current time.
3) I test timers, and sometimes manuals are confusing so I write out the steps to make sure I understand correctly.
4) It is possible that timer is defective.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
To override time and turn on Load, move override to ON position.
26helpful
I have ge model 15119 24 her timer and need help on how to set
GE 15119 timer is a 24-hour plug-in dial-type timer.
Dial rotates as time passes.
Plastic segments located around outer edge of dial control on-off operations.
Each segment represents 30 minutes of 24-hour day.
Timer comes with segments down.
Each segment can be lifted up using small screwdriver under edge of segment.
Segments down, timer is ON.
Segments up, timer is OFF.
So if you want timer to turn on at 7pm and turn off at 11pm, then lift all segments around dial except segments between 7 and 11.
Dial is divided into two parts > day and night.
Nighttime hours are shown by numbers with dark background >> notice small crescent moon where 12 midnight is located.
Daylight hours are shown by numbers with light background, and sun symbol shows at 12 noon
To set current time, so timer knows what time it is right now:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There is override switch located on one side of timer.
Move switch to Timer ON position and timer program will function.
If you want to turn lights ON using override switch, move switch to OUTLET ON.
Last steps:
Turn lamp on.
Plug lamp into timer.
Plug timer into wall.
1helpful
When one timer on my GE 7 Day, 8 Outlet Power Saving Strip Timer turn off the whole timer side turns off same when it turns on. how do i set them up so they turn on and off at diffrent times?
found a link for PDF instructions:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15077-Manual-eng.pdf
Top General Electric Hardware & Accessories Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
