SOURCE: six axis controler
http://answers.yahoo.com/question/index?qid=20080119225152AAVr2Ow try this link or this one........ thttp://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1293131....hope this helps
SOURCE: PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
SOURCE: Ps3 wont connect controller
if your controller works fine using the usb cable then is not your blu tooth card inside the ps3 the blu tooth only works when the contoler is not connected with the usb cable try to push the PS logo for 2 times in your control using the usb cable and then wait a few seconds and see what happend
SOURCE: My controller will not connect on my ps3.
Sounds like the controller knows it belongs to the other PS3. It has already "paired" with one console, so that's why you're having a hard time trying to get it to pair with console #2, comprende?
Make sure console #1 is a "hard off", like switched in the back. Now flip your controller over & put a pencil or pen tip in the reset hole. ( Just to the right of the center screw hole.) NOW connect said controller with the USB to console #2. Hold the PS button for two seconds. All 4 lights will flash 5 times, then the 1 light should stay on, Boo-ya! You're PAIRED!
SOURCE: problems to register (pair) the BD Remote Control PS3
Be sure to only press enter and start. I was accidentally pressing the direction ring that surounds the enter key. This was preventing the pairing from working. You must press the enter key with your finger nail.
Hope it helps:
Pairing is a process of associating
Bluetooth devices with each other. It will establish a permanent
security link between the devices and enable quick access to the
services provided without the need to re-enter Pass Keys. You will only
need to pair your PS3 and the Headset once.
Paired devices remain paired
even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be
'paired' so they can communicate with each other. Use a gaming
controller for this procedure and ensure that the Headset is powered on
(flashing blue LED light) and that it is not being charged via USB
cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X
on "Accessory Settings."
3. Press X on the icon labeled: "Manage
Bluetooth® Devices."
4. Scroll down and press X on the icon
labeled: "Register New Device."
IMPORTANT: Depending on
your model of the 8860 Bluetooth® Headset, your power button is either
an oval shape with an icon of a circle with a line going through it (5a)
or it is a button with a phone icon (5b). Please follow the appropriate
next step depending on your model of the 8860.
5a. Once at the next screen, prepare the
Headset to be paired with the PS3 by holding down the K1 button until
the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the
Headset to be paired with the PS3 by tapping the pairing button located
next to the volume controls on the side until the LED flashes BOTH Blue
and Red.
6. Once the Headset's LED indicator is
alternately flashing Blue and Red (indicating the Headset is ready to be
paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will
recognize all Bluetooth devices within range.
8. Locate "8860" from the list of
available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass
Key and press X on OK
10. You should then be taken to a new
screen stating: "Register completed"
Trouble
Shooting
Q.
The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3
will have trouble finding the Headset. Either remove the Headset from
the paired device or turn off the Bluetooth power on the paired device.
Q.
The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40
minutes. It is highly recommended to fully charge the battery before
use.
Q.
No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time,
it may take some time for the Headset LED indicator to show charging
status with a steady Red light. Make sure the PLAYSTATION 3 is turned
on. The 8860 cannot charge without the console being turned on.
Q.
No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have
been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters)
of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
