Hi!
After a huge financial splurge enlarging my wii system I found that I am supposed to send my console out for repair which will take much too long to get back. The guys at the game store said it's a pretty quick fix and it's the shipping time alone causing the delay. Since my spouse is a hardware guy I am sure that he could handle a repair like this, unless I need have new components added. Before I urge him to tackle such a repair himself, I was looking for info on what I would be getting him into! Thank you for any guidance you can offer! Please advise!
Regards,
Crystal
Need to know what it is doing?
If Wii gives unreadable disc, first step you need to check is to try
another disc or clean the exisitng disc. This will confirm that problem
is with either Wii or Disc. If the console itself is giving disc read
error then it needs to be repaired. You may check out DIY Wii Fix Guide,
that will show step by step information to fix the problem yourself. It
also gives information on fixing many Wii Related Problems, so its a
kind of Wii Problems Reference Fix Guide
Hi
there
From
what you have said it sounds like you have the DISK READ ERROR
The
main cause is Hardware failure due to overheating or just simple wear
& tear.
You
will need to perform simple maintenance to your console
You
can send your Wii to Nintendo to fix this. If your in warranty its
free. If not the repair cost would be $150 and a wait time of 4-6
weeks
The
other solution is what I did and the way more and more gamers are
turning nowadays is a Good
Wii Repair Guide that shows you how to fix the problem yourself.
I have never had a problem with this one so far for over a year, well
worth it. Its my most recommended guide online.
Well
this is all the help and advice I have on this so good luck.
You
can get back to gaming
Please
come back and rate my post if you find it useful
Many
thanks
Chris Foley
Hello
there
From
what you have said it sounds like you have the DISK DRIVE READ ERROR
The
main causes are Hardware failure, overheating or wear & tear.
You
may need to perform simple maintenance, clean or in some cases adjust
settings.
To
get the best advice on where to start I recommend a Wii
Repair Guide
, From this you can fix the problem at home and avoid any large
repair bills. Its easier than it sounds when you have help from the
guide.
The
other solution would be to send the console off to Nintendo, This is
free if your still in warranty. If your console is out of warranty
then the usual price of repair is $90
Glad
I could Help!
Good
Luck & Best Regards
Pete
Hi
there
From
The
& tear.
You
You
weeks
The
Well
You
Please
Many
thanks
Chris Foley
Hello
there
From
The
You
settings.
To
Repair Guide
guide.
The
Glad
I could Help!
Good
Luck & Best Regards
Pete
I played the game bully (cool game) for 6 hours straight because i rented it and wanted to beat it in 5 days. it started to lag then froze and said "unable to read disc". then i unplugged my system and waited a day then i plugged it in and tried super mario galaxy and it said the same thing so i tried wii sports and zelda (for gamecube),no luck so im wondering if i should turn it in for a new one or ask u.
