SOURCE: vertical green line on left side of screen rear projection tv
fuses may have blown out i think..
It may be the beginning of convergence failure. IF so, it will eventually fail totally and you will be faced with a $400 repair.
But, could be something less severe. I cannot guess precisely because there are many possibilities and only way to tell would be taking voltage and other measurements in search thereof.
It could, for example, be the convergence lines crosstalking into the video signal. Transistor switch somewhere in the system may need changing. It would require testing to find out.
If you do have an extended warranty policy it should be covered under that, so check that angle out before the police expires.
It will be a convergence issue, probally needs green convergence board repaired/replaced
