SOURCE: DXG-565V Flash Media Camcorder: my DXG -565V Flash Media Camcorders sd slot wont e...
There is a spring that puts pressure on the SD card. It is most likely stuck.
You will need to fish around with a straightened paperclip, but be careful not to bend anything or the slot won't work properly any longer.
this has happened to me a few times and it's always the same fix...the spring is jammed and needs to be coerced back into place.
Hope this helps!
SOURCE: My DXG luxe ultra-thin camcorder will not read the
hi! the possible problem for this is in your SD memory. Try to fix your SD memory card by formatting it. This will solve your problem
