20 Most Recent
DXG Technology DXG-566V Camcorder Questions & Answers
I HAVE A DXG DIGITAL CAMERA. WHEN I HOOK UP THE
Here's my problem: I recently bought as in today a PNY Optima 16 GB SDHC Card for my DXG-566V camcorder. When I inserted the card into it's SD card slot (which I assure you I did correctly), and powered up the camcorder, the camcorder didn't recognize the SD card, as it was still running off of the camcorder memory! Now I know the camcorder is just fine becuase after that I inserted my PNY 8 GB SDHC Card and the camcorder recgonized the card.
Please help me out here!
Memory Full...always
You need as SD card.
It only comes with 32 MB of memeory. That almost useless. Get 2 0r 4 GB SD card.
Took our DXG camcorder to
If you can clean the corrosion off down to the metal, you will be ok. Spray some electrical contact cleaner on them to flush off all the chemicals, and wipe them dry with a soft cloth. You may have to use some fine grit emery cloth to get all the corrosion and oxidation off the terminals. Then reclean them good. Corroded and oxidized battery terminals are the number one problem with digital cameras, since they use such a low voltage, and it's extremely critical to keep the contacts clean and perfectly conductive.
Cleaning the contacts should get you going again. Good luck, and thanks for using FixYa.
How do you get an LG LV720 video cassette recorder out of safe mode?
To get your LG LV720 video cassette recorder out of safe mode, you can follow these steps:
Locate the original remote control that came with your VCR.
Look for a button marked as C.LOCK or LOCK.
Press this button. This should allow you to exit the safe mode3.
If you don't have the original remote, you might face some difficulties. Some users have reported success by pressing the record button for 6 seconds on their Panasonic VCRs but it's unclear if this will work for an LG model.
Movavi video editor 11
which type of system you use ? if your computer is not equipped with the requirement, this will not work properly,
