Download the latest iTunes to your computer and reset the iPhone. Then re-sync it. Reset To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears. If iPhone won't turn on, or the display freezes or doesn't respond More resets: Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Restore
SOURCE: iPhone 3g White Apple Logo Screen of Death
Press and hold Sleep/Wake and Home until the iPhone resets.
When the Apple logo appears release Sleep/Wake, but do not release Home until you see the prompt to connect the iPhone to iTunes.
to restore the iPhone’s firmware, all your settings, all your media, and all your Apps.
I don't recommend you to do the offered backup, I've seen a few things more reliable then this backup, to say the least...
To avoid the screen of death, do not update all the features with the "Update All" feature, updates your features one at a time, avoid performing other tasks while updating your iPhone.
SOURCE: my apple iphone froze on the apple logo
Connect your phone to the computer and open iTunes. Hold both the home key and the power button until the iPhone turns off. Continue to hold them both for 5 more seconds. Release the power button but continue to hold the home button for 10 - 15 more seconds. I tunes should detect the phone in DFU mode. Restore firmware from this mode.
SOURCE: My iphone got stucked on the apple logo
here is a small tutorial that my help you....good luck I hope this helps please don't forget to rate
http://www.youtube.com/watch?v=u4xLvpazV24
SOURCE: My Iphone 3g 8gig is stuck on the Apple logo
Try each of the following resets:
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
SOURCE: my iphone 3G does not starting up it simply shows the apple logo
U PLS do as i say ..............Open iTunes and connect the iPhone to your Mac or PC
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black like this:
NOTE***: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!
