Google Chrome Logo
Posted on Nov 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i open google chrome an error accurt Whoa google chrome has crashed restart now
Cliff
Level 2:
New Friend:
  • Expert 45 Answers
  • Posted on Nov 27, 2010
 Cliff
Expert
Level 2:
New Friend:
Answers
45
Questions
0
Helped
10764
Points
157
Uninstall google chrome
redownload it from http://www.google.com
and reinstall it
will solve the problem
2answers
Google chrome crashed on my laptop, how can i relaunch or fix it?
Ctrl+Alt+Del and open task manager. In processes, sort on names and remove all references to Chrome by stopping processes. Go to applications and remove any reference to Chrome. If you have a cleaning program such as ccleaner, run cleaner on registry and computer.
Try to restart to see if the error has been resolved.
Good luck.
Google chrome keeps shutting down
Hi J Lanser,
I have this link for you on how to fix Google chrome keeps on shutting down. Hope it helps.
Whoa Google Chrome has crashed
2helpful
5answers
Google chrome keeps crashing not sure why
You need to check out all these:
1. Check for Conflicting Software:
- Some third-party software can cause Google Chrome to crash. When this happens, you'll see the message "Whoa! Google Chrome has crashed. It's possible that you have malware that can cause Google Chrome to crash.
- Google Chrome has a hidden page that will tell you if any software on your system is known to conflict with Google Chrome. To access it, type chrome://conflicts into Chrome's address bar and press Enter.
- You can try to fix these crashes by updating, disabling, or uninstalling any conflicting third-party software listed in "about:conflicts" on your computer. Also, take a look at Google Chrome's known issues for specific solutions to resolve crashes caused by some software.
2. Scan for Malware
- This includes malware and network-related software that interferes with Google Chrome. Malware can also interfere with Google Chrome and cause it to crash.
- You can try using Malwarebytes, or other anti-virus software to scan for and remove malware or you can also try searching the web for information related to any conflicting modules listed on the chrome://conflicts page (Windows only), to see if there are other steps you can take to remove malware.
- Many crashes are caused by malware. If you're experiencing frequent crashes, try scanning your computer with antivirus software.
3. Solve Flash Crashes
- We have found that the Flash plugin Chrome includes can cause it to crash in some cases. If you are seeing regular Shockwave Flash crashes, you may want to try disabling the internal Flash plugin and using the standard Flash plugin in Google Chrome.
4. Switch to a New Profile
- Chrome crashes may be caused by a corrupted profile. You can test this by creating a new profile from Chrome's Settings screen. Open the Settings page from Chrome's menu and click Add new user under Users.
- Change to the new profile after creating it and see if the crashes continue to occur. You can sign into Chrome with your Google account to sync the data from your old profile. However, Google recommends you don't copy any files from the old profile folder by hand - they may be corrupted and causing the problem.
5. Fix System File Problems
- Google recommends running the SFC.EXE /SCANNOW program to check for - and fix - problems with protected system files on your Windows system if you are encountering crashes. To do this, locate the Command Prompt in your Start menu (press the Windows key and type Command Prompt), right-click it, and select Run as Administrator.
- Type the following command in the Command Prompt window and press Enter:
SFC.EXE /SCANNOW
- Windows will scan your computer for problems with system files and fix any problems it finds.
6. Hardware issues
- It can also cause Chrome crashes. You may want to test your computer's RAM and ensure it isn't faulty.
· If still problem not solve, maybe you should try these simple steps:
1. Try restarting your computer first. It could be that the computer has just encountered a slight glitch on your system, which is causing things to not work properly.
2. Remove and Re-install the Google Chrome application. Doing this will allow your computer to read the files a lot better and faster, and also repair any damaged or corrupt files that have been causing the issue. To remove the Google Chrome application, first insure that you have another browser, such as IE or Firefox, click "Start, Control Panel, Add / Remove Programs," locate "Google Chrome" click UNINSTALL next to it. When the application loads, select "REMOVE" (not repair). Follow the uninstall process, and restart your PC. Problems uninstalling or re-installing Chrome indicate mal- or spy-ware, which must be dealt with.
3. Remove any extensions that you have on Google Chrome. Although they are a great way to personalize your Internet browsing experience, they are not so good for speed and functionality, as many can cause the application to crash. To remove any extensions follow these steps: Open up Google Chrome. In the address bar type chrome: //extensions. Click Uninstall, or Click Disable if you think you may use the add-on in the future. Restart your browser.
4. Disable plug-ins. Chrome can get bogged down with plugins that you aren't using, also. Type about: plugins into Chrome; it will redirect to chrome://plugins. Disable any that you aren't currently using.
Hopefully your Google Chrome crash problems are gone. Hope it works. Sharing is always caring.
Google Chrome always crashed,version 13.0.782.218,Windowns 7 SP1.Help
I do not think that this a problem with Google Chrome. It is probably just a problem with your internet. Something that you could try is...
Restarting your modem (and router if you have one). To do this, you can't just turn them on then off again. That will not solve any connection errors. What you need to do instead is a full restart. To do this, you need to shut down your computer, then shut off your modem (and router if you have one) and wait 5 or 10 minutes. This will send a message back to internet provider, and they will manually restart it for you. When the time is up, turn everything back on and see if Chrome crashes.
A way to test that it is actually Google Chromes fault, is to try using a different Web Browser and see if it still works then.
I cannot open multiple windows..i am using google chrome...it always crash everytime i tried it.
When you open too many windows on Google Chrome,you are making the browser take up more memory space.More the tabs you open, More the memory space you consume,more dangerous it is for the application(Google Chrome). Since the chrome.exe cannot withstand too much of load on it,it will crash.
You can observe that chrome crashed with too many tabs open will crash on restart too. It is because of the same reason that you make chrome to consume more memory for its operation.
I m getting message--- "whoa,google chrome has crashed.plz restart". plz help
Hi. i think you did not receive software with out any error. try to download once again but before going to install new one, try to think about deleting the old under uninstall software for better
I am getting chrome was crashed. Close and restart it now? ok or Cancel Whar ever we click it closes. after opening it again the same problem repeating.
This problem come only when the set-up has some errors.In case of crashed set-up, download the new set-up and then install in your system ,through this you can getrid from this problem.
When iam opening google chrome, it suddenly shutdowing and displayin a msg that chrome has crashed, restart chrome now. what can i do
It is a registry error. Run a registry cleaner to fix the error. Firefox creates registry key it may be error in registry key. May be dll is missing so you can run registry cleaner reg in out to solve it.
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
