SOURCE: a rainbow circle of color has suddenly appeared on the screen,
if there is a speaker near the set it will draw the color out
SOURCE: 37HL67 37 in. HDTV LCD Televison - My Toshiba was
The tv Tuner signal board is the problems that causes this whiteout.Its the board,that take in the incoming broadcasting cable signal (plugged into it)
I would suspect either the main board or the t-con board, with the main being the most likely cause. Without an oscilloscope its going to be hard to isolate between the two. Most commonly its the main pcb. The main will have the tuner mounted to it where the rf cable is connected.
