SOURCE: What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
SOURCE: Oven trouble
Do Not try to perform the below if: Oven is under warranty,You are not handy with a soldering gun, or Are afraid to do this.
The below solution applies only to my in-wall oven with F2 and F3 codes randomly, but presumably will work with other GE models.
I had the same trouble with a GE in-wall oven. The problem was on the electrical board behind the keypad. A pin that was soldered to the board, that was the input for the oven temp sensor, had cracked solder. So I re-soldered the pin and hopefully it will continue working.
If this fixes your oven please post back!
SOURCE: Maytag Gemeni double oven stovetop stopped working
Thats the controller, you'd need to call a professional no quick fix for that one sorry. besides attempting to fix it your self will cause more damage than good
SOURCE: Maytag Gemini stove with the f-1 and f1-2 problem
your lower oven temp sensor is bad. part # 12001656
SOURCE: Oven rarely comes up to temperature Maytag MGS5870ADC
It seems to be thermal issue .
Check thermocouple .
