20 Most Recent Maytag MGS5770 Gas Kitchen Range Questions & Answers
The spark module should be behind the rear panel of the range, or behind the bottom drawer, mounted on the interior back wall. If you go to searspartsdirect.com, the part is listed as item number 22 under the "Gas Controls" heading. The part number is 74004283. Just type in your model number and follow the links on the next page. There are helpful drawings to assist you. If in doubt, trace the wires from the the surface igniters and they all will lead back to the spark module. I hope this information helps you. Let me know if you need further assistance.
Maytag MGS5770... | Answered on Jan 26, 2014
F3 is a failure in the oven sensor circuit. That circuit being from the ERC outlet pin to the harness, to the sensor and back to the ERC return pin. Could be a bad sensor that is failing under heat conditions, or possibly a connection that is failing as the unit heats and it expands. The temp of the sensor at room temp is 1050-1100 0hms and goes up 100 ohms for every 50 degrees from there. If you can get it to fail, and ohm it out, you will know for sure. I will tell you a sensor is a heck of a lot cheaper then an ERC and is more likely the culprit. Here is the sensor to order.
Maytag MGS5770... | Answered on Dec 01, 2012
F1-E5 - Calibration Shifted - Disconnect power for at least 30 seconds and then reconnect. Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Maytag MGS5770... | Answered on Nov 13, 2012
Number 13 and 22 is the parts I suspect.
13 is the ignitor which even if it glows could be weak, It must pull at least 3.5 amps to open the gas safety valve. The spark module(number 22) could also be weak and not putting out enough juice to light them burners. Seen it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Maytag MGS5770... | Answered on Nov 11, 2011
Have you seen this video:
Most time it is on the back side under a shield
Move a shield and you will find it
This stove has these sealed burners:
Give em a twist and lift these puppys out like this:
If it ain't on the back then remove the bottom drawer and it will be under a shield in there.
Hard to tell on the diagram
Must be a bad oven control. Looking at the wiring diagram I see a hot wire from the power terminal to the fan and onwards into the ovencontrol. Must be a fried relay on that control board. Ya might want to remove the control and look for signs of failure.
Maytag MGS5770... | Answered on Nov 10, 2011
Hi rosebud1239,
The F9 fault code error description is about the door latch. Please check the door latch components.
Hope it helps.
Thank you for using FixYa.
Maytag MGS5770... | Answered on Sep 22, 2011
Maytag MGS5770 Gas Kitchen Range Logo
88 questions posted
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Kitchen Ranges
Most Popular Question
self cleaning codes
  • Kitchen Ranges
