D-Link DP 301P (DP-301P) Print Server Logo
Anonymous Posted on Nov 17, 2010
Cannot print, no connection Config D-Link Print Server DPR-1061 on 192.168.0.80 / 24 Windows 7 (x64) on 192.168.0.40 / 24 Norton Internet Security 2010 D-Link PS-Link 2.31 I can ping the the device but PS-Link does not discover it and the printer is "Offline"
  • Anonymous Nov 26, 2010
    No, that's not the problem. I have another machine (Vista) which can print to the device. I don't think you have sufficient expertise to resolve this.
    Please, someone must be able to better than that!
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Dec 20, 2010
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3073276
Points
27242
Sorry we are not able to help you with you problem.
Anonymous
Level 3:
  • Master 1,851 Answers
  • Posted on Nov 26, 2010
Anonymous
Master
Level 3:
Answers
1851
Questions
Helped
513534
Points
5186
You need to change it to 192.168.0.0 - try that - it is the default address of the units.
Gary @ Fix Ya
  • Anonymous Nov 27, 2010
    I guess you're right - please accept my apologies - i wish you the best with your printing.
    Gary @ Fix Ya
2answers
Printing on HP Laserjet 1020 connected to the network through DLink DPR-1020 print server
did you resolve this issue , beacause have the same problem with a Toshiba e studio e223 ?
1helpful
I have print server d-link dpr-1020 connected to laser printer hp P1006. My PC is running under windows 7 Pro. Print server is connected to linksys wrt120n router by cable. My PC is connected to the...
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
Is it compatible with windows 7?
The latest firmware for this print server only support Windows Vista and below , sorry to say that as of now it will not work with Windows 7. If Dlink releases a new firmware to make this unit with Windows 7 just need to update the firmware and you can use it for Windows 7 computers.
1helpful
GMfPSU21W6 usb print server support windows 7 & Vista
When I upgraded from XP to Windows 7, Iogear tech support told me that they had no intention of offering Windows 7 support for my GMFPSU22W6, so I dumped it and bought a D-Link DPR-1260 instead.
2helpful
Windows 7 compatibility forthe DPR 1260
My DPR-1260 arrived yesterday and I set it up easily in minutes on both Windows 7 (32-bit Pro) and XP SP3 with 3 printers attached. So far I have only tried wired connection. Wi-fi may be more problematical.
Printers are Brother HL-2040, HL-2140 and Samsung CLP-300. Could not get it to recognize my Canon Lide 25 scanner
Can not install
Chapter 3 - Configuration
This section will show you how to configure your new D-Link wireless print server using the web-based configuration
utility.
Web-based Configuration Utility
The IP address of your print server will be automatically assigned by your router.
To access the print server’s web-based configuration interface:
Windows® XP users:
Double-click on the My Network Places icon on your desktop. Your print server will be displayed as “DPR-1260:
dlinkps-xxxxxx” (where xxxxxx is the last 6 characters of your print server’s MAC address). If you do not see the print
server or have UPnP enabled, please refer to page 13.
Windows® 2000 users:
You will need to write down the MAC address located on the bottom of the print server (E.G. 00-54-23-45-f5-b6). Open
a web browser and enter the following:
http://dlinkps-XXXXXX
XXXXXX = the last six characters of your MAC address.
Note: Some printer software features may not work
while connected to the print server such as ink level display.
This will prove the print server is working. If you can not access the web interface then it may not be getting an address from the router
D-LINK DPR 1260 NOT DETECTED
did you install the software that comes with the print server? if so, did you configure the software to recognize the printer?
1helpful
2answers
Print server configuration in canon mf4150
I had the same problem. After many hours of trial and error, I got two XP laptops and a Vista desktops configured. Be sure to use the latest firmware from Dlink. Disable all s/w firewalls. In my case Norton Firewall from Yahoo was a problem. The Vista PC was configured to print within 30 mins and the XPs took a while. I couldn't get the print server to appear in the My Network Places A couple of the guys who left comments on the product at Newegg actually have a good solution. The solution involves setting the printers up as local printers with standard TCP/IP ports that point to the IP address or the URL ("dlink-"6_last_digits_of_MAC_ID) and USB port number 9100-9103. You can google how to set up local printers w/ TCP/IP connections with USB ports on the internet. Note the Scanner will not be recognized but at least you can print on MF4150.
4answers
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
