Place the items inside the unit and close the door. Set the cook time, then press the "Power Level" button. When the display asks for input, press "5" for 50% power. Then press START.
After first setting the cook time---then hit the power level button and hit the number 5 (for 50%) and then start. Power level can also be changed while running by hitting power level button and selecting 1 through 10. For example level 3 is 30% for defrosting.
You have to put the cook time in first and then you press the power level button (just below the number 7 on the keypad) and put the power level in. The choices are 1 through 10. Fifty percent is probably power level 5. Once you have put in the power level, just push the Start button and it will start cooking.
you have to enter your cooking time and THEN hit the "power level" button. Most likely, the display will read "the current power level is set to 10" or something like that. just go ahead and put in the number for the percent you want. For example, hit 5 for 50% power. Then, hit "start." eat
Press he power button and select a number 1-9. If you press 20 it will use 0 as the power. The numbers correspond to percentage of time the cooking energy is applied during the cycle. 5 is 50% so it will be cooking for 30 seconds out of each minute. 2 would be 20% and 9 = 90%. Hope this helps... Eric
It depends on the brand and model, but it's generally:
Time Cook, 2, 0, 0, Power Level, 5, Start or just 2, 0, 0, Power Level, 5, Start.
You can
download GE
owner's manuals and installation instructions here. You should be able to download your LG / Goldstar manual here. If not, you can contact them via that page to order one.
You
can download owner's manuals and installation instructions for
several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid,
Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
First enter the cooking time just like normal, but then you hit the power button and then hit the digit indicating the power level you want. THEN hit start and it will start cooking.
The numbers DO NOT equal a certain power level Erin. They equal a percentage! This is very confusing. Even the factory reps. can't explain it adequately. I recently replaced my old 600 watt oven with a GE 1100 watt model. The 600 watt unit came with a great cookbook. (I searched the internet but couldn't find one for the GE oven and the factory was no help!) A chicken recipe in the 600 cookbook said cook on high for 30 minutes. Since 600 is approx. half of 1100, I cooked on high for 15 minutes. Result: Uncooked chicken...
The next time I cooked 30 minutes on 50% power (button 5) and It came out OK. I have since used 50% power with meats in cooking bags with good results. Remember to check for correct temp. with a meat thermometer when oven stops. Trial and error is your best test at this point I'm afraid. Also you may want to type "Microwave Conversion Chart" into your browser. You will get some additional information from this. But read carefully!
model#JET344JV-001
