There is no reason for you to run at .75 ohm. For one your Amp is rated 1.5-4ohm. So if you wired the sub in series making it a 3ohm load you are getting the most power out of the amp. Running it at .75 ohms won't make it any louder.
It's not good for that speaker at all to be wired to 0.75ohm I have one and I am tell no reason in the world to wire it any way other then specs.
I am also pretty sure then when I was hooking my sub up it was wire to 3ohm. I have 800.1 kicker amp pushing it and brother I am telling you with the amp you have its sound should be the best in your town... So take the suck back out and take the 1#coil+ hook to 2#coil- and you should be good to go that's how mine is
There is no reason for you to run at .75 ohm. For one your Amp is rated 1.5-4ohm. So if you wired the sub in series making it a 3ohm load you are getting the most power out of the amp. Running it at .75 ohms won’t make it any louder.
1000/1v2 Class D Monoblock Subwoofer Amplifier Specifications: Rated Power: THD at Rated Power: S/N Ratio: Frequency Response: Damping Factor:
1000/1v2
1000 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
<0.05% @ 4 ohm
>95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
5 Hz - 250 Hz (+0, -1dB)
>500 @ 4 ohm / 50 Hz
According to the chart your amp is only stable down to 1.5 Ohms, so running at .75 Ohms the noise you are hearing is the amp clipping (running more power than it can handle at low ohms)
I would suggest wiring it in series, or you could adjust the gain on the amp until the popping goes away.
Hope this helps.
