MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS; UP/DOWN TO CHANGE THE PARAMETERS; \ *C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT; SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET; RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT; DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED; DETAILED INFORMATION TO SET THE CLOCK INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING; when watch displays time and everything .....
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time;
Saludos , solo hay que mantener presionado el boton MODE por 10 segundos y de hay juhar con los botone up y down. Suerte
Hi, Hold 10 Sec MODE button, you will know to how to change (Combo Button mode and UP and DOWN)
Good Luck
SOURCE: how to set the clock
http://www.fixya.com/support/t6744593-change_time_kadio_clock_3809 for solution
Thanks
