Trouble Shooting Steps to by pass the login password
STEP 1: You can by pass this Screen by resetting the router for 30 seconds with the power cable alone connected to the router. You can find the reset button to the right side of the power connecter. And all the settings on the router will be lost and you need to reconfigure one by one again. That is the only solution for this problem
STEP 2: Then connect modem to the router using an ethernet cable one end of the cable on the actual modem and other end in the belkin router on the yellow slot or isolated slot called as "Connection to the Modem"
STEP 3: Then take a second ethernet cable and connect from the router wired slot in any like 1,2,3 or 4 and the other end of the same cable to the computer
STEP 4: And run the Setup CD o setup ur Router again
First you should know your internet service provider details like connection type
Connection type may be of Dynamic, Static and PPPoE
STEP 5: After setting connection type check whether the status is connected on the belkin screen on the right top corner and and if connected go ahead with the wireless settings like
Channel and SSID
Security
Kindly refer the attached screenshot. Which will be more helpful for u.
Thanks and Regards,
Sunill.
