Hello s poteet> My name is Roger and I will help you. The fuse for the cruise control will be located in the fuse panel located on the left side of the steering column under the dash. Locate the fuse listed as METER. Should be second fuse up from the bottom in the middle row of fuses. This will be a 15 amp fuse and blue in color. This is the only fuse that pertains to the cruise control. Should you need further help please just ask. Please rate the answer you received. Thank You for using Fix Ya. Roger
