The TV died 18 months after purchase. I did not buy extended warranty. The technician tried swapping the motherboard but that did not fix the problem. Now the tech believes the LCD itself could be the issue. Does anyone have any advice here
Do this test and it should tell if the lcd panel is bad or not, turn the tv on and touch the screen in the center, push with your finger firmly but not to hard, if you have a backlight or light shows up around your finger then it is probably the T-con board/panel, the T-con board is attached to the lcd panel and is less expensive to replace, if you do not have any light then it's probaly the power supply
I have the same problem as discribed by kashmiri2. I contacted Samsung and they will do nothing to stand behind their defective product because it is 6 months out of warranty. $2,600 is what I paid. Don't buy Samsung products.
