SOURCE: Unit plays DVD but no longer Blu Rays
That is because of a dirty or defective lens. When lens is dirty, the unit may still operate on regular CDs and DVDs and not be reading BD.
Try first using a lens cleaner for Blue Ray:
Maxell 190054 Blu-Ray Lens Cleaner
If that does not work, the unit may be disassembled, and lense cleaned
with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Being this a blue ray unit , I would suggest calling support instead of disassembling the unit by yourself.
Regards
SOURCE: Samsung BD-C5500C with latest firmware will not
I don't think this is a software update issue. Just as you said that the player has the latest firmware installed on it. Software update and latest firmware are the same thing.
I think this is a incompatibility issue. The disc is not 100% compatible with the player and that is why there is no audio via sound.
But one more thing you can try is to enter the player's menu, under settings, check audio settings. You can change the sound settings to mono, save settings and try again.
Good luck.
