The grinder does not work at all. Coffee pot makes a pot of boiled water. Grinder worked one day, next day it wouldn't.
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
DGB-500 grinder does not work at all = grinder does not start:
>>>>> I fixed mine following these steps:
1 unplug the AC power cord from the ~120V AC power plug
2 Drain all liquids from the DGB-500 (DGB-550)
3 Unscrew (5 screws) the top front control panel plate having the timer display and 6 buttons
4 Unscrew the printed circuit board (PCB). Avoid ESD - electrostatic discharges that can damage the PCB electronic components
5 Unplug and clean the oxide on the printed circuit board connector pins (has 12...18 multi-color wires and pins)
6 Connect back the PCB connector
7 Test for grinder start-up by closing/pressing down on/ the top contact for the blades box (present/absent)
8 Screw back the PCB; mount back the control panel
coffee not flowing into pot but rather onto counter
