Freezers Logo
Posted on Jun 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freezer Problem I have a Frigidaire upright freezer (Model LFFU1465DW6) that is a couple of years old that is located in my garage in Houston, TX (garage temperature is about 100F). A few months ago and then again yesterday, it quit cooling and the temperature within the freezer got high enough for the food to begin defrosting (50F+). I unplugged the unit, waited a couple of hours, plugged it back in and it started to freeze again. I don?t recall now if the compressor was running or not, but the power light was on. Any suggestions?
  • Anonymous Mar 30, 2014
    It has power, but there a '-' on temperature control and the internal light does not work. Unplugged it and the temp control light went dark. Plugged it back in and the '-' comes back. Food began to get soft on the top shelf The freezer never runs despite being opened while I emptied it. Unplugged it and the temp control indicator went dark. Plugged it back in and it lit up again with the '-'.
Anonymous
Level 3:
  • Master 828 Answers
  • Posted on Jun 10, 2008
Anonymous
Master
Level 3:
Answers
828
Questions
0
Helped
454970
Points
1944
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Where can i find the repair manual for frigidaire freezer model lffu1465dw6
Good Afternoon Gene, thank you for your question! I understand you are seeking a repair manual on your Frigidaire freezer, LFFU1465DW6. I have located the Owner's Guide, Wiring Diagram and Parts Manual on the manufacturer website. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
1helpful
Can we leave the wooden pallet on the bottom of freezer?
Hello Rebecca - The styrofoam and wooden pallet attached to the bottom is part of the shipping material and it is recommended to be removed. If you decide to leave it attached it should not cause any damage, however keep in mind that it might trap moisture under the unit and cause corrosion.
I have a Frigidaire upright freezer model# ffu20f9gw3. The temperature alarm light is on. Cold air is blowing but the ice cream melted, and the hot dogs are still frozen and loaves of bread that i...
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
1helpful
2answers
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
2helpful
New freezer. 15 days old. mildew smell in the
There is a curing process for the foam used to insulate these. It can give off a pungent odor until it is fully cured. Only experienced it a couple times in the last 20 years. eric
3helpful
Whining sound from motor on Frigidaire upright freezer
Hi: It sounds like you bought a frost free freezer as it has a fan. The fan will come on to circulate the air. It will not necessarly run continuosly. The noise is most likely coming from the fan. I sold Frigidaire freezers for years and they are noisy compared to a refridgerator. If you think it is louder than it was when you bought it, I would replace the circulating fan. Also look at the back wall for frost as it could be a bad defrost heater blocking it with ice. Most likely just the fan though. Since it's in a detached garage,and you won't have to put up with the noise inside your house, it could run a while before failing. The fact it's getting cold is a very good sign.Also as you asked 2'nd, a freezer is ok in an unheated garage. Don't put a refrigerator in there. Unless It is a Whirlpoll Gladiator that is designed for such applications. Use www.searspartsdirect.com to find out where the fan is if you feel it is necessary to replace it. Its not a tough job if you are handy. Their shipping is expensive so you might want to buy it locally.
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
