Cell Phones Logo
Posted on Oct 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I would like to unlock my Lg kf750 for free so i can use my vodafone sim card
Anonymous
Level 2:
  • Expert 337 Answers
  • Posted on Oct 29, 2010
Anonymous
Expert
Level 2:
Answers
337
Questions
0
Helped
116363
Points
685
If you get the unlock code at free means, it is not safe and sometimes data lose also,
you can get the unlock code at very low cost itself, through this site http://www.mobile-unlocker.com/lg-kf750/rs2wp9/
It has the best instructions and easy methods for unlocking your mobile phones.......
Anonymous
Level 3:
President:
  • Master 2,360 Answers
  • Posted on Jan 04, 2011
Anonymous
Master
Level 3:
President:
Answers
2360
Questions
0
Helped
669367
Points
5015
Try unlocking sites
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Vodafone co uk simswap
If you have up your SIM in a Vodafone store, it'll already be activated for you. You can just insert it into the mobile phone and start using it.
If you ordered a free SIM online, you'll need to call 17298 free from your Vodafone mobile to activate it.
Note: Before activating (registering) a Vodafone SIM card, make sure that the mobile phone is locked to Vodafone network or free from network restriction. If it is locked to any other network, you need to unlock it in prior. You can unlock a mobile phone safer and easier using unlock code. If your mobile phone is a Blackberry model, You can visit UnBBLock.Com to get the unlock code. If your mobile phone is from any other model, visit Mobile-Unlocker.com to get the unlock code. Good luck.
Free unlocking codes ks360
Free unlock code is not possible to get for LG KS360 model phone.You need to pay for this model to get unlock code.Visit the site Mobileunlocksolutions.com get unlock code for this LG phone and unlock it easily.Then use Vodafone or any GSM network sim card in it.
1helpful
Hi my name is prem. i have lg kf750 u.k.vodafone.this phone is restart.so what i do?
Hi Prem,
If your phone is constantly restarting one thing you should do is to take out the battery from the phone and leave it out for about a minute or so then put it back in. If this doesn't work, if your phone has a SIM card, (the card your cell phone provider usually gives you) then take that out along with the battery and put it back in after 5 minutes. But first you should try taking out the battery.
3answers
I currently have a Vodafone SIM but am switching networks. When I put the new SIM in, it doesn't work. I have been told I need to put a PUK code somewhere, but Vodafone isn't telling me anything on where...
The Vodafone SIM card will only work on the Vodafone mobile network. If you want to use different mobile provider then you need to purchase a new SIM card from that mobile provider.
If you intend to use your old mobile phone that was connected to Vodafone, then if this mobile phone is locked to Vodafone, then the new SIM card from a different mobile provider will not work in the old mobile phone unless it has been unlocked to allow you to use any SIM card/mobile provider.
If you need to unlock this mobile, then please leave me a comment so I can provide you with further information.
2answers
Unlock the LG KU990i Viewty mobile
990i's can only be unlocked with proper equipment.
alternative way is by code lg themselves.
i have account with them so can supply you code
normally within 48 hrs. cost is £16 or 18 euros.
you can pm [email protected] if you need more info
Lg displays 'insert usim' and does not allow any functions
sounds like its either one of 2 things:
1. the sim card is locked. (you'll need to call your service provider & get them to give you the puk code to unlock it)
2. the sim card has crashed (go to your wireless provider & get them to provide you with a new sim card)
hope this helps...
1helpful
Displaying unregisterd sim
Unregistered SIM usually indicates the SIM card you are using has not been activated. Call your provider to ensure the SIM card number you are using is the same one they have in their systems.
Need to unlock my kf750 to put in any sim card
umm.... u need to take it to a mobile shop to unlock it.
2helpful
2answers
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
