20 Most Recent LG KF750 Cellular Phone Questions & Answers
Battery not Charging
Need new battery
10/15/2017 7:18:06 PM • LG KF750... • Answered on Oct 15, 2017
Unlocking the usim and then phone
Better get LG customer service
10/2/2017 8:06:40 PM • LG KF750... • Answered on Oct 02, 2017
NCK code to unlock my LG KF750
Hi, you can use the factory unlocking service for your phone model here: http://www.fastgsm.com/en/lg/lg/kf750/unlock-code-usim-locked
10/25/2012 3:34:28 PM • LG KF750... • Answered on Oct 25, 2012
How to fix lg kf750 secret touch pad .the top and
1)My lg k750 touch screen has become a nightmare only lower one works at will the rest are dead so what do i do? less than one year old
2)outbox hangs messages how is it solved
9/22/2011 12:59:49 PM • LG KF750... • Answered on Sep 22, 2011
0answers
Lgkf750 blinking lg logo when turned on like to
Welcome to Fixya
Sounds like the phone's firmware is already corrupted. Try to troubleshoot it first. Remove then memory card and sim. Remove battery for 5 mins. Press and hold the power button for 15 secs without the battery. Put everything back to the phone then turn it ON. Try to reset the phone back to he factory state if same thing will happen. Press and hold the Volume Down, Call and the Power buttons, until the LED (at the side of the camera) flashes. Release the buttons. That LED should flash in green/red/blue. After doing the procedure the device should be cleared from errors.
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
7/12/2011 3:21:00 AM • LG KF750... • Answered on Jul 12, 2011
0answers
Hi i have an lg
Be the first to answer 7/8/2011 2:59:50 PM • LG KF750... • Posted on Jul 08, 2011Be the first to answer
My phone is so slow.camera is showing
Failing to operate some function like camera,gaming,internet browsing,message sending etc. might due to a memory full problem. if the phone memory free space is too low, it will not allowed any operation as what above stated.
To avoid this problem, be sure all multi-media files are stored on memory card or mass memory storage. delete unused file for saving memory space.If still the same way around, you need to format or reset your phone by going to settings then master reset.be sure to back up all important files first before doing this method cause everything will be erased. It will ask for a confirmation code then enter 0000, after entering the code it will automatically restart the phone .Your phone is now sets on original default settings.
Hoping this method helps...
7/2/2011 4:43:06 PM • LG KF750... • Answered on Jul 02, 2011
2answers
I cannot to delete my
go to settings and restore it to default (reset)
default code is 0000
6/23/2011 9:48:29 AM • LG KF750... • Answered on Jun 23, 2011
How do you reset the LG KF750?
You can go to "Settings",
Then "reset settings".
The Code for the reset should be 0000.
Though I personally haven't tried it, I'm told that you should NOT lose any data, just custom menus.
Best Wishes and Good Luck!
4/10/2011 9:45:18 PM • LG KF750... • Answered on Apr 10, 2011
Hi my name is prem.
Hi Prem,
If your phone is constantly restarting one thing you should do is to take out the battery from the phone and leave it out for about a minute or so then put it back in. If this doesn't work, if your phone has a SIM card, (the card your cell phone provider usually gives you) then take that out along with the battery and put it back in after 5 minutes. But first you should try taking out the battery.
2/28/2011 11:26:48 PM • LG KF750... • Answered on Feb 28, 2011
I Cant fine lg pc
Hello thanks for using fixya
Download it and enjoy
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
2/1/2011 11:19:21 AM • LG KF750... • Answered on Feb 01, 2011
I new lg celluler kf 750 made in korea afer one
Try to charge the phone and power it on, take note, if the chargers metallic point makes contact with the metallic part of the charging port, then the phone will not come on unless you remove the battery and insert it back in. Ensure the battery's metallic point is making proper contact with the phones battery terminals.
First of all you need to run a quick check on the phone before we can conclude that the phone is bad and need to be repaired. Remove the battery and insert it back in then try to turn it on. If it does come on, then that solves the problem, if it does not, then you need to carry out some further test to find out what the problem is.
First check if the battery is properly charged. To do that, insert the battery into another phone and turn it on to see if the battery will power up the phone. If it does not power up the phone, then you know that the battery is either weak or bad, then you charge it using a universal charger or a normal charger to see if it will hold a charge, if it does power up the phone, then it means the problem is not from the battery but another component in the phone.
Try out a well charged battery inside the phone and turn it on, if it comes on then the phone is intact and the solution is for you to replace your battery. If it does not come on, then there seem to be a problem with the phone.
If these are not the cause of the problem, then you will have to take it back to the dealer that supplied it to you since you might still be under the warranty period, for them to either repair the phone or replace the phone for you. Be sure to have your warranty card with you, if not the dealer will not be able to offer any form of assistance to you.
The phone might have fallen or hit a hard object and that might lead to damages inside the unit of the phone.
Hope this helps!
12/18/2010 7:38:50 PM • LG KF750... • Answered on Dec 18, 2010
2answers
How to find the model of the cellphone
your phone model no is -LG KF750
8/28/2010 4:42:58 PM • LG KF750... • Answered on Aug 28, 2010
How can I unlock an LG KF750 phone?
To unlock your mobile you need to get network unloack code(NUC) from current service provider via phone or go to service provider office.
While you get the Network unlock code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only.If they are satisfied with your answers they will provide with the network unlock code.
Thanx
8/26/2010 8:36:42 AM • LG KF750... • Answered on Aug 26, 2010
My screen displays the information twice as two
its strip problem its time to get it changed
8/24/2010 2:07:12 PM • LG KF750... • Answered on Aug 24, 2010
Unlock
As you have not mentioned which unlock code you need i am hereby specifying how to unlock various codes in the mobile phone.
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer caredepartment.It is free of cost.
Therestrictioncodecan be got from your old service provider..This restriction code iskeptto prevent someone who stole themobile from using it withanotherprovider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
It is all free of cost donot pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above proceudre works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4035818-need_unlock_nokia5130c_2_use
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
7/11/2010 8:53:47 AM • LG KF750... • Answered on Jul 11, 2010
Hi i have an LG secret and when ii slide it up and
Hi, you can go to the security lock of th phone or the keypad lock of the phone to activate slide lock.
Use the manual of the phone to get there.
Take care.
7/3/2010 11:03:58 AM • LG KF750... • Answered on Jul 03, 2010
LG KF750 Cellular Phone Logo
Popular Tags
59 questions posted
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
LG Cell Phones
  • LG Cell Phones
Most Popular Question
reset lg kf750
  • Cell Phones
