Jenn-Air JJW8130D Electric Single Oven Logo
Posted on Jun 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jenn air oven stuck closed after attempt to activate self-cleaning
My wall-mounted jenn air oven door is stuck closed after a failed attempt to activate the self-cleaning function. I don't know what model # it is, since that info is on the top INSIDE of the door, out of my view.
I would appreciate help
  • Anonymous Mar 30, 2014
    The door does not lock to begin cleaning cycle
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
714
Points
Door is stuck after self cleaning
Anonymous
Level 3:
  • Master 413 Answers
  • Posted on Jun 10, 2008
Anonymous
Master
Level 3:
Answers
413
Questions
0
Helped
209728
Points
1203
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jenn Air JJW9630. Why doesn't it start cleaning cycle?
After 20 years of faithful service, your Jenn Air deserves retirement.
Sep 10, 2021 • Ovens
Jenn-Air model WW27430P. After heating to set temperature and baking for 8 to 10 minutes, why does it shut off?
It's faulty and in some sort of self protect mode. You need a service call or you can try some of the fixes here.
FIXED - WW2780 Jenn-air oven keeps shutting off ...
www.applianceblog.com > mainforums > threads > ww...
Feb 15, 2012 - Hi.... I have a Jenn-air oven model WW2780 that keeps shutting off after being turned on, almost always during the preheat. From what I have ... Missing: WW27430P ‎' Must include: WW27430P
Jenn Air Range Stove Oven - Oven Won't Turn Off - Repair ...
www.repairclinic.com > RepairHelp > Jenn-Air-Oven-...
Here are the most common reasons your Jenn Air oven won't turn off - and the ... Enter model number to search for the required part specific to your product.
HOW-TO: Jenn-Air Oven WW27430P Door won't close
www.appliancepartspros.com > repair-help > ww27430...
Door won't close is the most common symptom for Jenn-Air WW27430P. ... I have a Jennair jjw9630cas double wall oven, and after a few years I noticed that the light would not go out, first in the bottom ... Door pulls shut and li8ght stays off.
HOW-TO: Jenn-Air Oven WW27430P Won't start or doesn't start
How to Replace Oven Temperature Sensor Kit for Jenn-Air WW27430P Won't start # ... Jenn Air stove JDS9860CDB00 error code 1d11 oven not shutting off. ... Very easy on this and other models with this sensor-- just two screws holding it in ... Rating: 5 · ‎123 reviews
Nov 17, 2020 • Ovens
Oven door falls
jenn air wall oven
dont like the design of the hinge itself
door section has to be locked in ..
but by the design of the door capture sure looks like
the door can be removed for easier cleaning
Have a wall mounted Jenn-air oven. Have used self-cleaning feature before. Followed step by step instructions to the end including locking the door and pushing "Enter". Went to bead expecting to wake
This is a general answer and not specific. The oven thinks is still in the cleaning mode. If it has one, push the clean button again. Set the oven to a regular bake cycle.
OVEN NOT WORKING
You have probably damaged the latch and other sensors around the door. Make sure that the is not bent or out of alignment.
more asst.
[email protected]
Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Apr 17, 2008 • Ovens
Jenn-Air Oven - Model W46 - Door Lock Lever came loose
you have to turn the breaker off then pull the oven out from the wall till you can get the top off the motor is at the front you will see how it goes
Jenn-Air self cleaning wall ovens model W2451
We have a W245 self cleaning oven and the woven gasket is falling apart, can we purchase a new one to replace it?
2answers
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
