Have a amana NFW7200TW washer the drain pump gave out replaced it and now when i turn on the washer the water just keeps draining out i touch the pump and it is not on how do i get the water to stop draining out
have you tried unplugging and resetting the computer, it seams hung in the last cycle, can you open the door and remove all inside, reset it again and try it, the washer sounds like it has water in it and needs to drain first,if it is full of water you have to drain it, by moving it and taken the drain hose off the pump,if that's the case i recommend flushing the inside with hot water and some bleach right through the front door or reservoir on top,after you get it emptied, the water sensor may be full of soap, by the way the soap your putting in this machine should only be about a 6th of a cup, I know it sound crazy but a half or a 3rd is to much, for the sensors, try this an get back to me,Matt
I had the same problem, not sure it was your pump, load it with a bucket of hot water and some bleach, turn it on and let it run through a short cycle, the hot water and bleach can clean the sensor and the screen in the bottom going down to the pump, did water drain out when you took the lines loose, if it did its a good sign, most people dont realize you use only a quarter or less cup of soap in this washer, it will get the sensor water sensor dirty and the washer thinks it has water when it doesnt, the pump cant drain cause there is no water, . try the hot water trick, rmember use a bucket and as hot a water as you can, probably hair sudds and who know what is blocking the sensor, mine was hair, from my little girl, Matt
make sure it a drain pump, they same will fit Samsung ,amana and Maytag, make sure it not just stopped up remove it and look at the impellers, i put one in to find out it was the water sensor was soaped up and telling the washer it was full when it was empty and i would get a nd on the front , no drain,Matt, need the answer to fix that let me know.
remove the hoses and and remove the pump then use coat hanger to try to clean inside pump and try to turn propeller by hand depending on ur model some pumps cant be taken apart depending on either direct or belt driven ones
Hi Thanks for using FixYa. From what I understand the error code ND means “No
Drain issue”. You’ll need to check for any restriction in pump assembly. It can
also be due to a restricted drain hose or loose wire at pump. If after cleaning
the drain hose the issue is not resolved then it means the pump has gone bad
and unfortunately needs to be replaced. Please do rate the solution if the issue is
resolved or post a comment for further assistance. Thanks Rylee
