Crane Elephant EE-3186 1 Gallon Humidifier Logo
Posted on Oct 26, 2010
I tryt to turn on my humidifier tonight.1st the mist was coming out just little bi,but there was no green light on,like the manual sed and the humidifier was making some wird noises too.
Anonymous
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on May 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
23
Questions
Helped
25899
Points
36
Welcome to Fixya!
  • Ensure that the water tank cap is secured properly to water tank.
  •  Empty out water in water basin. Place filled water tank on to empty water basin.
  •  Clean Water Level Sensor.
Hope this helps!
Mainstays Cool Mist Humidifier 1 gal MDH-0103JW Low Tank Indicator Auto Off NEW Manual
Here are the instructions for the Mainstays Cool Mist Humidifier 1 gal MDH-0103JW:
  1. Remove the water tank by lifting it straight up and off the base.
  2. Turn the water tank over and remove the tank cap by turning it counterclockwise.
  3. Fill the tank with cool water and replace the cap by turning it clockwise.
  4. Place the tank back onto the base, making sure it is seated securely.
  5. Plug the humidifier into an electrical outlet.
  6. Press the power button to turn on the humidifier. The power light will illuminate.
  7. Press the mist button to select the desired mist output level.
  8. The humidifier will automatically shut off when the water level in the tank is low.
  9. To refill the tank, repeat steps 1-4.
Note: For optimal performance, it is recommended to clean the humidifier weekly. Please refer to the user manual for detailed cleaning instructions.
Nov 06, 2022 • Humidifiers
My humidifier works but wont blow mist?
If it is an ultrasonic humidifier, it has a little disk about the size of a dime at the bottom of the well where the mist comes out. That metal disk gathers white scale on it, Clean that off. The best way I have found is with a Waterpik turned all the way up.
Feb 07, 2017 • Humidifiers
Venta Sonic VS205 Humidifier turns and has the green light, makes a buzzing sound, but no mist is coming out.
If you see mist in unit and not coming out fan motor in base of unit bad. Four screws in base and fan unplugs
No mist is coming out of it but the green light is on.
Hi Lisa,
  • Check that there is water in the Water Tank.
  •  Make sure that nothing blocks the Mist Output Slots.
  •  Check that the Fan Vent on the bottom of the humidifier is not blocked.
  •  Empty the humidifier and rinse the Water Basin with cool tap water and allow to dry for 15 to 30 minutes before resuming normal operation.
  •  Check for possible mineral deposits on the Water Level Sensor or the Nebulizer.
For more information, check out the owner's manual here. It is truly helpful!
Good Luck!
4helpful
2answers
Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Top Crane Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
