20 Most Recent Optimus U-31005 2.0 Gallon Cool Mist Ultrasonic Humidifier Questions & Answers
the little hose from the tank to the top is clogged
Optimus U-31005... | Answered on Feb 04, 2016
This a repair forum, you need to deal with manufacture. If you look on the instructions that came with unit, the warranty info is there and the place to return it.
Humidifiers | Answered on Jun 05, 2019
The unit may have developed a defect and will have to be replaced.
Humidifiers | Answered on May 25, 2019
when you post the same question 6 times in a short period a lot here just ignore them. food for thought.
Humidifiers | Answered on May 14, 2019
check makers website
Humidifiers | Answered on Apr 25, 2019
fixya doesnt sell parts for anything
Humidifiers | Answered on Apr 23, 2019
After replacing the Water Panel, turn the control knob to the “Test/Reset” position until the “Change Water Panel” light blinks to reset the Water Panel change indicator timer.
Humidifiers | Answered on Apr 09, 2019
You need to check to make sure the condenser fan is blowing and that the condenser coil is clean. You absorb heat inside the refrigerator, compress that heat with the compressor, then expel the heat at the condenser (the part of the system that blows hot air). If you can't expel that heat, the unit will lock itself out until you reset it
Humidifiers | Answered on Mar 30, 2019
I DON;T KNOW. MOST WATER IS LET IN WHEN NEEDED BY FLOAT VALVE AT BOTTOM OF BOTTLE OR LOWER.
PERHAPS IT NEEDS CLEANING. CONSIDER USING
STRAIGHT VINEGAR IN LEAKING SIDE THEN GOOD SIDE. IF NOT OK, YOU MAY HAVE TO TAKE UNIT APART TO INSPECT FOR CAUSE.
Humidifiers | Answered on Mar 20, 2019
https://tadanoamerica.com/dealers
If anyone using Fixya is searching, this is a link to dealer phone numbers in the United States to request.
Humidifiers | Answered on Mar 15, 2019
Optimus U-31005 2.0 Gallon Cool Mist Ultrasonic Humidifier Logo
Popular Tags
2 questions posted
Top Optimus Humidifiers Experts
Paul Carew
Dennis Webber
Marvin
Marvin
Are you an Optimus Humidifier Expert? Answer questions, earn points and help others
View Most Popular
Optimus Humidifiers
  • Optimus Humidifiers
Most Popular Question
bought humidifier in january
  • Humidifiers
