Cell Phones Logo
Anonymous Posted on Oct 25, 2010
My friend has accidentally blocked my number on his phone he can ring me but I can't ring him I'm o2 and he's on orange. He wants to remove the block so I can ring but doesn't know how to do it. Pls help
WIRELESS IMAGE
Level 2:
  • Expert 282 Answers
  • Posted on Oct 25, 2010
WIRELESS IMAGE
Expert
Level 2:
Answers
282
Questions
0
Helped
52258
Points
987
Usually its under the security settings to unblock callers.
Panasonic - KX-TGD530. How do I delete all the blocked numbers on my KX-TGD530 please?
I have a phone KX-TGD530 with call block. I accidentally
JustAnswer https://www.justanswer.com > Electronics Question
Jun 25, 2018 - I accidentally blocked a number. I have been trying to unblock the number but everything I try does not work. PLEASE. Tell me what I can do.
1 answer · Top answer: Hi, I'm Nathan. Sorry to hear that you're having trouble, but I'll do my best to help you. ...
How to remove / unblock a number from the blocked calls list.
Panasonic https://help.na.panasonic.com > answers > how-to-rem...
Follow the instructions to learn how to unblock/remove a number that you no longer want blocked. ..
Dec 09, 2023 • Cell Phones
2answers
HOW DO I BLOCK PHONE NUMBERS ON MY WILDFIRE MOBILE?
There are 2 ways to block numbers:
1. Go to Menu. Settings. Call. Call services. Call barring settings.
There you can block outgoing or incoming call groups using your provider's network settings.
2. Press menu, and then tap All friends.
In the Friends list, press and hold the friend's name you want to block.
Tap Block friend. Your friend is removed from your friends list and is added to the blocked friends list.
Aug 08, 2011 • Cell Phones
An orange mobile phone number is contacting my wife with calls and texts and when we try to ring back it is always on answer phone. Regards, Bob.
if its really bothering you, lodge a police report for harrasment, then ask orange and your carrier to block that number.
1helpful
I have an nokia 6080 im on orange, my sim card has been blocked with an puk number as my friend was messing around without me realising an blocked it please tell me my puk code. thanks
Hi
It should be on the starter pack which came with your sim card.
Or you call the customer care with a friend phone number and tell them you need your puk number and it will be given to you immediately.
Regards
3answers
How do i change my imei number on my blackberry 8900 curve< it was blocked by orange
You cannot change an IMEI number.
The IMEI number (International Mobile Equipment Identity) is unique to the device itself and is hard coded. If it has been blocked that would normally mean that the device has been lost or stolen.
Presumably that is not the case here, so can you exlplain what has happened and I will try to help.
Apr 10, 2010 • Cell Phones
Sir, I have accidentally blocked my SIM. My phone is asking for the PUK code and pin number. My phone number is 9487677333. My SIM number is 8991808023461532407N. Please send my the puk code and pin numer
hiya
to get this , you need to call your mobile operator eg:orange , tmobile as this is blocked because you entered your pin number incorrectly more than 3 times
it is easy to do just ring up and tell them what happend sometimes you can even do it online via their website
Aug 29, 2009 • Cell Phones
5helpful
3answers
Block one number from calling and texting me
Hi
some Samsungs have a 'block list'. I am quite sure that the D900 has it. All you have to do is when you receive a text from this number select options, and you should see in sub menu 'add to block list'. I am not sure if it also blocks calls once added to the list? Hope that helps?
Cant find puk code to unblock my phone
if you contact your service provider (O2, orange vodaphone etc...) they will issue you with a puk code.
You will need to write down your imei number from inside your phone, because they will ask you for it. Turn your phone off, remove the battery and you will be able to see the imei number.
I hope this helps
Puk
no, u need to ring your sim provider e.g o2 or orange... and tel them your phone number, they will give you your puk and you can change your pin simple.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
