Contributor
- Posted on Oct 25, 2010
Re: When entering a game I hear sound but no picture....
If you are sure that you have your TV on the correct input, you can try resetting the PS3's video settings using the following procedure:
- Before changing cables, make sure the PlayStation 3 is turned off
using the main power switch on the back of the PlayStation 3 (the 0 side
is pressed down).
- Unplug the power cord of the PlayStation 3 and television (or display) from the wall socket.
- Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PlayStation 3 system.
- Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
- Plug the PlayStation 3 and television (or display) back in to the wall socket.
- Turn the main power switch on the back of the PlayStation 3 back on (the line on the power button is now pressed).
- While the PlayStation 3 system is in standby mode (red light on the
front of the system), hold down the touch-sensitive On/Off button on the
front of the system until the system goes into standby mode again . (So
the light cycle would go from: red light to --> green light -->
then back to red light) This will ensure that you have held down the
On/Off button long enough to reset the Video Output Settings.
- Turn ON the PlayStation 3 and once the system finishes powering up,
the Video Output Settings will automatically reset to the standard
resolution (or detect the current display output settings of your
TV/monitor).
If that does not resolve your issue, try the other steps here:
http://us.playstation.com/support/answer/index.htm?a_id=262
