Huskies are the Best! Please remove the feeder plate - under the needle, and look for any fabric still jammed. Remove any way you can - small screwdriver, nail-file. (It will take removing a small screw or two.) Unless you find metal parts, broken bits, you did not break anything. Removing bunched fabric should do it.
On the other hand, if you do find broken parts - Viking is Amazing! They can machine broken parts of sewing machines and guns, back before 1900! Love them! Just remove any parts related to where fabric cound be jammed, remove all you find, and try again.
SOURCE: husqvarna sewing machine - viking 400
Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
SOURCE: Need to get a copy of Husqvarna viking 500
Go to Husqvarna Vikings web site and use the dealer locator. Put in your Zip code and your nearest dealer will come up. You should be able to order it over the phone with a credit card.
SOURCE: Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
SOURCE: I need a foot pedal for a husqvarna viking emerald
ebay but recommend dealer to make sure you get the right one. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
SOURCE: In need a user manual for a Husqvarna viking sewing
I found this download for $5.00 - http://gotoes.org/sales/VikingSewingMachineManuals/ViewInfo.pl?Viking=1&Sewing_Machine_Model=6440
