Sharp AR-M237 Digital Copier Logo
Posted on Jun 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp AR-M237 Error Code H4-21
I replaced the fuser but it keeps coming up with error Code H4-21.
  • Anonymous Mar 28, 2014
    error H4
  • DW Jack
    DW Jack Jan 28, 2018
    Using the code to reset the printer would be great if the keypad worked. But alas, because of the error code, everything is locked. Anyone know how to clear the error so that I can try anything to get this printer to work?
Anonymous
Level 2:
  • Expert 146 Answers
  • Posted on Jun 06, 2008
Anonymous
Expert
Level 2:
Answers
146
Questions
0
Helped
173831
Points
590
-H4-21 means:Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch. Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
If the error code recurrs ther are other problems.
Kel2
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 17, 2012
Kel2
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5546
Points
Thankz guys you all save me some money
1 Related Answer
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Mar 21, 2011
SOURCE: SHARP AR-M237 H2-00 ERROR CODE---HAVE INSTALLED
H2.00. Thermistor open
Diagram Sharp SIM14?
Type # - interrupt - C - interrupt and clear the code with simulation 14 and then hit CA to exit. If the code comes back there is a problem with your fuser (dirty thermistors cloged with toner, or one of the lamps are out)
2answers
SHARP AR-M237 H2-00 ERROR CODE---HAVE INSTALLED NEW FUSER UNIT WITH SAME ERROR/CODE PROBLEM.
check harness and connector betwen thermistor and control PWB.
clear the error code by using SIM 14 if all didn't work you may have defective AC power supply
I hope this help
2helpful
Sharp AR-M237 Error code H4-01
Error code H4-01 means low temperature.
4helpful
2answers
Sharp copier ar-m236 error h4-21
try to reset by programming...here u just do ..p * c * (p star c star ) u will go in simulation mode .then press 14 ,start .mechine will ask you yes or no ? u just press 1 for yes .and press start ...your mechine will work..if same problem prsist try to check fusing unit...dont forget to thanks to me
11helpful
2answers
Sharp photocopier with error code L4-01
Hello sir L4-001 that's driving problem, check the main motor ,gears belts.
16helpful
4answers
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
1helpful
How do i clear error code on AR BC-260 H5-01
I don't have that error code specifically but any error code that starts with an H has to do with the fuser section of the machine. It could be the thermistor, rollers, or the heat lamps.
It should be looked at by a Sharp technician to determine the correct problem.
26helpful
5answers
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
