Let's first try this: Search for the file with extension ".car" (dot car) using the windows search wizard, don't forget to select the hidden files in the search options. You need to type in "*.car" (start dot car *this is for your reference only*) in the search box and search in the whole directory of your computer including the other partitions. Hopefully you'll find some or maybe that man 2010.car. If so, open the file directly so that the program "Printmaster" will open up. This should fix your problem is there's no other registry related issue/s. Well, you may not find the file, in that case, close the opened program (if so) and open any "Printmaster" .car file. Restart your computer and check if it goes or persists.
If this isn't helpful, save all the .car files or files created by the "Printmaster" and uninstall the program (I hope it's possible with your PrinterMaster version to be reinstalled, you need to have the key), You'll also need to run registry cleaning using a registry cleaning tool like Ccleaner (freeware). Download and install it, run the "Registry" cleaner and restart your computer, again (re) install the Printmaster and see how it goes. Let me know if you have problem.
Good luck.
Thanks for using FixYa.
I HAD PREVIOUSLY TRIED THE SUGGESTED SOLUTION AND IT DID NOT WORK. I DO NOT FEEL COMFORTABLE IN TRYING TO WORK IN THE REGISTRY SO I WILL TRY TO RECREATE THE CARD AND IGNORE THE ONE THAT CANNOT BE OPENED.
THANK-YOU.
