Hello Projocs03,
Tires are typically measured tire width (sidewall)/tire ride height/wheel size. The differences of the two tire sizes you published are .4 of an inch difference in width/sidewall. And about .55 in over all diameter which would impact you revs per rotation. Depending on your wheel size.
Attached is a comparison of the two given the variable of 17" rim.
Stock Tire
>Search Tires
Tire 1 - 255/70R17
>Search Tires
Tire 2 - 265/70R17
>Search Tires
Section Width:
Section Width:
10.03 in
255 mm
Section Width:
10.43 in
265 mm
Rim Diameter:
Rim Diameter:
17 in
431.8 mm
Rim Diameter:
17 in
431.8 mm
Rim Width Range:
Rim Width Range:
6.5 - 8.5 in
Rim Width Range:
7 - 9 in
Overall Diameter:
Overall Diameter:
31.05 in
788.67 mm
Overall Diameter:
31.60 in
802.64 mm
Sidewall Height:
Sidewall Height:
7.02 in
178.30 mm
Sidewall Height:
7.30 in
185.42 mm
Radius:
Radius:
15.52 in
394.20 mm
Radius:
15.80 in
401.32 mm
Circumference:
Circumference:
97.54 in
2477.5 mm
Circumference:
99.27 in
2521.4 mm
Revs per Mile:
Revs per Mile:
669.8
Revs per Mile:
658.2* Source http://www.1010tires.com/TireSizeCalculator.asp?action=submit
I added the above link so you can research further or change any variables you need to know. However, the most important thing to understand is the impact of your speedometer. Different sizes will have different impacts. For example going to a bigger tire will show a slower speed on your spedo that your traveling.
Good luck
I'm looking for capstan belts too, for a Sony CFD-C1000 - anyone know if there is any source of 'generic' belts? This is just a glorified rubber band; 200mm circumference, square x-section 1mm.
Marrs Communication sells belt kits if you do not know what size you need.
