My canon zr300 mini dv camcorder keeps ejecting tapes, can't get a tape in to record or anything My Canon ZR300 video camera is having the same problem. It just started two weeks ago. When I insert a tape and try to close the lid it beeps and says "remove the cassette" and the lid will not close all the way. I tried a newly charged battery and a new tape several times and it still has the error. The manual said something about a camera malfunction and this message is to protect the tape. I was hoping I would be able to troubleshoot without having to send in for service but I have not seen any posted solution.
Hi guys,
Thank you very much for this solution posting. Really it worked. I was about to buy another one instead of fixing the problem. Because you know how the pain is, to send it factory and getting it repaired.
Once again Thank you.
Wholey ****!!! that actually worked!!! I tried tapping it once or twice with no avail, then I punced it 5 or six times and it worked!!! lol.
Wow! The "Fonzie" method really did work for me too! I put my camcorder on my bed with the tape enclosure (closed) facing me and I gave it a good whack with my fist. I turned it on and it accepted the tape. THANK YOU SO MUCH!!!!!
Just wanted to add one more testament to the fact that this actually worked.
This absolutely worked, my husband can't believe I was able to fix it!!!
Holy ****! it worked....right before we were gonna throw it out the window...dont know how well that would of worked?!
Worked for me
I cannot believe this but it does work
I had the same problem for a while, i was about to send mine in to be repaired, but i tried this, and the tape has loaded
I just had the same problem and tried the solution, it worked!
May, 28 - I just tried the below solution today and it worked !!!
ericemartin
Rank: Apprentice
Rating: 100%, 1 votes
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
Wow.....it worked. Thought I was going to have to buy a new one..............
camera will not record..it displays a message that>:
tape is in erasable preventive mode..
