Acer 22" X223w LCD Monitor Logo
Rhenne Leon Posted on Jan 24, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Acer Monitor H233H has internal speakers. The sound used to work now it doesn't. Could it be something that has been accidentally turned off or disconnected? How do I get the sound back on, This just happened in the past week and the monitor is less than a year old. [email protected]
  • Terry
    Terry Jan 24, 2018
    Hi Rhenne Leon, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Which version of Windows are you using, e.g. Windows 10 or Windows XP?
    Take a look at this web link to see if it helps and let us know one way or the other:
    https://answers.microsoft.com/en-us/wind...
Narseman
Level 3:
President:
  • Master 1,088 Answers
  • Posted on Aug 21, 2022
Narseman
Master
Level 3:
President:
Answers
1088
Questions
Helped
311467
Points
3782
Assuming windows PC.. First, check the wire connectors are solid. Turn everything off and remove then replace all connections. Look for the speaker icon in your task bar. Bottom right of screen. Might be in the hidden icons box, right click on the speaker and choose settings from the popup menu. Wording may be different on diff versions, check to see the right set of speakers are selected. Sometimes plugging in ear phones, for example will change settings, and unplugging defaults to something else.
5 Related Answers
Anonymous
  • 293 Answers
  • Posted on Oct 06, 2008
SOURCE: 22" ACER MONITOR QUIT
93vette,
Well...what you need it a new backlight inverter. Your old one it's busted. If you got less than a year... you've got 3 yrs warranty on parts. Contact Acer asked them to send you a new inverter... Have a nice day!
Anonymous
  • 47 Answers
  • Posted on Jan 09, 2009
SOURCE: i have acer al1917w A monitor but no sound
go to you sound card configuration.. and set it to be 5.1 audio instead of "surround sound" which is only 4 channel 4 speakers. this what the issue seems to be
Anonymous
  • 73 Answers
  • Posted on Jul 25, 2009
SOURCE: Recently, I purchased an Acer H233H LCD Monitor
Try installing the Acer Monitor software and disabling the the desktop sound card under 'My Computer'. 'Properties','Hardware Devices'.
Let me know if you need help doing this, or need more help.
Anonymous
  • 10 Answers
  • Posted on Aug 26, 2009
SOURCE: Brand New ACER H233h Monitor
Have you checked through the setup controls on the flat panel. I've seen a few that had the audio turned off by default. That is sometimes done because it generates static noice if there is no audio sourced coming through them.
Anonymous
  • 130 Answers
  • Posted on May 24, 2010
SOURCE: Speaker in the Monitor?
It looks like there are no speakers according to:
http://support.acer.com/acerpanam/monitor/0000/Acer/X193/X193sp2.shtml
You should be able to use any external speakers to your system. The question is looks and power. You will likely have to buy speakers that have power in order to get enough volume.
Most speakers that come with monitors are of very, very low quality. You now have the option of buying good speakers (if you want to pay for them). If you are in a hurry you can likely pick up cheap speakers at the drugstore or Walmart. Another option is headphones.
Good luck finding the right sound.
1helpful
Where is/are the mic(s) on an Acer H233H display?
The Acer H233H does not have a microphone built into the monitor. Thus you do not have to put tape over the microphone. It does have integrated down-ward firing speakers; the speaker jack is next to the power cord on the back of the monitor. Make sure to connect the included audio cord to the Lime Green audio (speaker) out jack on your computer. All of the jacks on the monitor point down.
If this monitor had a microphone and the blue 3.5 mm audio port, you could keep the microphone disabled simply by not connecting the cable between the monitor and the computer's microphone port.
Acer has the documentation for the H233H monitor in their support section. The direct link to the manual is http://global-download.acer.com/GDFiles/Document/User%20Manual/User%20Manual_Acer_1.0_A_A.zip?acerid=633765057605336286&Step1=MONITOR&Step2=H%20SERIES&Step3=H233H&OS=ALL&LC=en&BC=ACER&SC=PA_6 . This file has the manual in a PDF inside of a compressed folder. You'll need to open the folder to read the manual.
I hope this helps. Web cameras often have microphones. Some laptops often have an integrated web camera; thus they have a microphone mounted on the bezel of the laptop. Blocking that microphone with tape might be useful. I'd block the camera too. For USB connected web cameras, simply unplug the data cable from the computer when you aren't using the camera to disable the microphone.
Acer h233h monitor has blue tint all over screen
It's any one of these issues in decreasing importance video cable, video card, monitor. Make sure the video cable is plugged into the monitor and computer firmly first. After that, start replacing until you hit the culprit. You should be able to take any one of these items back to the store if it doesn't fix it.
I recently bought the H233H monitor to use on my new Win7 PC. When I am viewing anywhere online all the background stuff shows up pink. Replies on Facebook are boxed in pink as well even though every other...
So, your "new" monitor is the only monitor with the problem ?
Exercise the WARRANTY for the Acer monitor, and get it replaced/repaired, at no cost to you.
1helpful
I am running Red Hat Linux Enterprise my new Acer H233H is saying Input not supported any help would be greatly appreciated. Thank you
It says input not support because the PC video resolution is too high for the monitor to display, just need to lower the resolution. Nothing to do with OS, just the video setting.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.productwiki.com/acer-h233h/
If you set to native resolution and it still does not work then you will have to open it up and inspect the inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
2helpful
2answers
Recently, I purchased an Acer H233H LCD Monitor with the HP e9180f Desktop. However, the built-in stereo speakers in the monitor are not working. The sound card in the desktop is fine, as headphones and my...
How to connect Acer h233h so that I can hear the speakers.
you should be able to get sound when connected trough any of the three port. best port to use is hdmi or dvi connection. adjust your volume on your computer and make sure your audio drivers are updated.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
