Behind the knobs for the right burners are 2 electrical switches that start the spark when you turn the knobs on. One of those switches is bad and stuck in the on position. You have to pull the knobs off and remove the trim behind the knobs to get to the switches.
The valve is 'seized'. Grease gets into them and over time turns acidic corroding the valve from the inside out. Replace the valve. Any appliance parts seller can get it for you. Turn off the gas before starting repairs!
-Did it just happened ?
If yes then some thing or food waste clogged that gas line.
If not. It's been like that since new then the factory that make this stove assemble by mistake.
Check it out
I just read this here: http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
If the knob fits tightly to the control, and turns the stem of the control, then I would be suspect of the control. But if the knob fits loosely, I would be suspect of the knob.
Not knowing age - very often older (standing pilot) ranges will have burner valves that become hard to operate. These are usually a tapered core valve that can be greased with a high temperature valve grease.
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
