SOURCE: Sharp R-1450 Microwave Oven
The most common suspect here is a shorted high voltage capacitor, since you say it blew the fuse right after Start, but I would certainly suggest checking the door switches and door switch mounts first. Just be sure you installed the right fuse. It would be a The switch mounts seem to break at about this point in the life of these models. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com (the three is correct)
SOURCE: randomly blows circuit breaker while not running, only the clock is on.
Normally when the circuit breaker blows, it a bad door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Microwave possible blown fuse??
If you still have this oven and need repair, we can do it for $39.95 nationwide or about $25 more if it needs a new transformer.
We repair these and various other models all the time with the same situation for RV owners & dealers across the country.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: microwave / Frigidare PLMV
What size breaker is protecting the circuit? Per the National Electrical Code, a microwave and a washing machine should each have their own dedicated circuit (and own breaker) rated at 20 amps. Also, if the breaker is old and has tripped many times due to continuous overloading, it may be weakened and could be tripping at a lower amperage than what it is rated. I would try the following:
1. If possible, test the microwave on another circuit and see if it trips that breaker. If possible, use a 20 amp circuit for the test.
2. If you're comfortable with working in an electrical panel safely, place a clamp on ammeter on the hot wire of the affected circuit in the panel and see how much current is being drawn when the microwave is on.
3. If you would rather stay out of the panel, get an inline ammeter/watt meter and plug the microwave into this. If the rating of the microwave is less than 15 amps (1800 watts), you may be able to use a device called a kill-a-watt at a local hardware store. This will show how much power is actually being used by a given appliance.
