Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
SOURCE: Casio watch band adjustment
Check the Citizen web site: http://www.citizenwatch.com/Technical/English/Service/pin1tube.pdf
You can skip the part about removing the split tube. Instead of their pin pushing tool, I used a short piece of straight pin held with long-nose pliers while I squeezed using medium sized channel-lock pliers. A helper to hold the watch would've been good.
SOURCE: How to adjust the straps and time on a Casio AQ230A-7B
For an instruction manual go to the following link.
http://world.casio.com/wat/download/en/manual/
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
SOURCE: battery replacement for casio wave ceptor wvq-200hu WATCH
Download abridged instructions from casio @ http://world.casio.com/wat/download/en/manual
SOURCE: adjust the time in a casio g-shock shock resist watch
You can get instructions from the Casio web site.
Go to the
casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read
the number of the back of your watch and enter it into the search box
Click
on "search" and the download your instructions.
