Televison & Video Logo
Posted on Sep 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I received an Error Code ( <>[e:20100924[]6039] ) on only 1 channel ( YTVe ). The TV Model is NS-LCD32F. A large Black Box Appears and the Error Code appears repeatedly but only on the 1 channel. The TV Appears to be having trouble with that Channel. When I change the channel and turn the TV Off, the problem seems to disappear.When I turn the TV on I am able to watch TV as long as I stay away from the one channel. I checked the channel on another TV ( not High Def. ) the channel works without any trouble which could rule-out my MTS PVR. I also reset the MTS PVR and the problem remained on the NS-LCD32F Model TV. Your assistance would be greatly appreciated.
Anonymous
Level 3:
  • Master 5,807 Answers
  • Posted on Sep 25, 2010
Anonymous
Master
Level 3:
Answers
5807
Questions
0
Helped
272294
Points
13914
Thanks in advance for choosing Fixya for assistance
I would like to make a clarification request on what
" Source " are trying to view programs on TV
Is it on the TV built in tuner or on the AV 'Input " ?
If ever you are watching through RF input , have you
tried connecting it using AV input?
If using AV INput have you tried other connecting cable?
or post cable you are presently connected.
Awaiting for your immediate answer and post the model
of your MTS PVR so we can start having possible solution
to your problem.
Led power light comes on but screen will not come on.
"Blinks a few times" implies the TV is flashing a fault code at you. If you can find a service manual for your model, count the number of blinks and look it up in the diagnostics section.
However, the most likely problem is a burned-out electrolytic capacitor in the power supply. These are usually easy to identify visually; the top of the can-shaped capacitor should be flat, but may be bulged out and may have brown or black material leaking from the vent scores. The photo below shows a bad capacitor to the right of a good one; both have black plastic sleeves.
If this is the case, replacement capacitors are relatively cheap. However, you should look for the following criteria in choosing a new part:
>Capacitance (uF): same as the original, or 10% higher if the original value is not available
>Voltage: same or higher
>Temperature: Maximum temperature should be same or higher
>Physical size: should fit in the space occupied by the original; if buying a taller unit, make sure it will fit when the back cover is reinstalled, and make sure the capacitor will not touch heat generating parts such as heat sinks, resistors or large transistors.
>Ripple current: get the highest available without compromising too much on endurance. Ripple current may be specified in mA or A; 1 A = 1000 mA. Sometimes you can get a better rating by going to a higher voltage part, but physical size may be a limitation.
>Endurance: Try to get 8000 hours or better.
I usually use Panasonic FR1 series capacitors, although United Chemi-Con EKZN capacitors are also worth a look. 25351068-tkog3zu3xmxabptjkcidpctj-1-0.jpeg
How to get unlock code for nokia lumia 520,imei :351737060551944
Hi. You can get the accurate unlock code for your network locked Nokia Lumia 520 either from the respective network provider or from trusted online vendors like MobileUnlockSolutions.com at affordable cost.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia Lumia 520 without any sim card.
2 - Don't bother as to what is displayed on your Nokia Lumia 520.
3 - Compose #pw+CODE+1#.
4 - The Nokia Lumia 520 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia Lumia 520 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia Lumia 520
4helpful
How to unlock a phone. Nokia lumia 520
Hi. You can unlock a Nokia Lumia 520 safer and easier using unlock code. You can get the accurate unlock code for your Nokia Lumia 520 either from your respective network provider or from any trusted vendor online like TheUnlockArena.com at affordable cost.
Instructions to tune Philips tv 54cm colour TV. Search & store channelss
Hello
You haven't mentioned about the model number of your Philips TV. Different models have different type of tuning procedures. Any way I hereby send a procedure to set it autotuned. If it Doesn't work, please inform me through Fixya, stating your TVs model number also. ok
Press "Menu" on the remote control handset, and select the installation language.
Select a language and confirm it by pressing "OK" button on the remote control.
Press ' button to return to 'Instalation' menu.
Press "Menu" on the remote control handset and select Installtion > Preferences > Location.
Select 'Home" and press "ok" to confirm.
Press ' to come to the Installation menu.
TO TUNE CHANNELS AUTOMATICLY AND TO STORE
Press "Menu" on the remote control, "Select Installation" '>' Channels '>' Autoprogram '>' Start now.
Press "OK" and allow the start installation automatically.
If you run autoprogram when you have locked channels, a messege appears asking to enter your PIN code in order to complete instllation.
Try this, if doesn't work inform me with TVs model number. OK.
I am trying to set up my new digitview 110 box, i have tryed to do an auto scan but it can not find any thing and i am not sure if i have the correct cabbles for it, any help would be great and even...
Make sure you have an ant. connected to the ant. INPUT on the>> 110 box <<then take a cable from the OUTPUT of >>110 box<< and connect it to the >> INPUT<< on your TV.
If you connect box to TV with a cable wire then put TV on channel 3 or 4
If you connect BOX to TV with the
Yellow red and white wires then put TV on VIDEO rather than channel 3 or 4 !
Auto program Digital Converter Box to receive channels...must have an ANTENAE connected to converter box!!!
1helpful
I dont know how to tune in channels on my remote
Press MENU,then press < or > to display SETUP menu, press V until TV/cable is highlighted. Press < or > to highlight TV or cable depending on which you use. Press V to select CH Program,press < or > to start channel programming,when completed appears,press CH + or - ...hope this helps..
Which jack ports on rear of dra f107 do i use to connect to tv,thanks
If you mean >>> DENON <<< DRA F107 and you want to connect TV-related audio to it...
Either run an RCA pair from the back of your (unknown make/model) TV audio out to the receiver's CD, Aux1 or Aux2 input. Then configure your unknown TV sound output to be FIXED if that is an option, so TV volume can be turned down at the TV but the receiver can still use the audio.
Better yet would be to draw TV-related audio from whatever the TV is watching: DVD, Cable Box, satellite box and eliminate the TV as the Low-Fi middleman.
Audio on some TV channels/shows goes off. It varies by channel, sometimes national feed is silent, but local break-ins have sound. I have to set the Audio from A.F.D. to Movie to get audio. Sometimes I...
Not sure what this means: "The audio comes to the Cable box through coax cable." From where does audio come TO the cable box? The cable box is a source of both audio and video. Perhaps you mean the TV broadcast "containing the audio and video" comes in on coax.
Has this ever worked correctly? <<<<<<<<<<<<<<<<<<<<<<<<
Try this: disconnect the HDMI that goes from the cable box to the Video 2 on the receiver. Leave the optical audio cable in. How's the audio now?
Then try the reverse: reconnect the HDMI and disconnect the optical audio. You shouldn't need BOTH for audio into the receiver.
Now what happens?
4helpful
2answers
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
