Question about Mitsubishi WS-55513 55" Rear Projection HDTV
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Hello i tryed my xbox360 on hd mode 1080i on my Mitsubishi 1080 series Integrated. the picture is there but u can hardly see it it moves all over the place, is it my tv thats mess up or do i have to change some settings on the tv. I tryed my WII on components an it works fine i know my xbox 360 works for HD 1080 we played it on my friends HD tv. Pleae help!!! The singnal goes crazy like its moving around.
  • mikeydembi Feb 01, 2009
    I have a similar problem. I'm pretty sure I've hooked my 360 cables up perfectly and switched the HDTV component on the back of the cables to on. For some reason the only color that my tv shows is green. It's like the red and blue HD cables don't show for some reason. Any suggestions? Thank you.
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
Posted on Oct 22, 2008
SOURCE:
Mitsubishi WS-A65 1080 HD Series Won't Switch from 480i to 1080i
Its main digital board has to be replaced. It is a skilled work. If you wish to get more details about this work, check the site linked below and pull up older posts there.
Apr 22, 2013 | Televison & Video
I bought a used mitsubishi ws 55513 and when i turn the tv on is says 480i stretch. How do i use the 1080?
U don't get to chose modes.480,720 and 1080 it chose by the tv show itself.Want more 1080 must have HD package from cable or satalite compannies.
Jan 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 wont go from 480i t0 1080
Tries CBS or NBC channels have HD if displayed 1080i than ur box is working.The shows must say HD or Display 1080i to work HD programming.
Jan 15, 2010 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
1080i
Using the DTV input on the back via component cables to an HD source you then need to make sure the input assignment menu is adjusted to Y/Pb/Pr
Feb 25, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Cant go from 480 i to 1080 any suggestions?
How do you have your Blu-Ray player hooked up?
First, you have to set your Blu-Ray player to output 1080i (the highest resolution that the Mitsubishi WS-55511 can support). Then you hook up the player via component to the DTV component input on your set (it's the only input that can handle 480i/p and 1080i).
Good luck.
Danny
Dec 25, 2008 | Mitsubishi WS-55511 55" Rear Projection...
I am trying to get 1080i HD on my mitsubishi 1080 series. how do i do that.
Component Video Inputs Will Carry 1080I signals through Component Cables
Mar 24, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Cannot get my tv out of 480
you have to go into the xbox 360 settings and change the output screen resolution to 1080i and also check your tv settings input to receive 1080i also.
Sep 10, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
835 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
