20 Most Recent
Mitsubishi VS-60111 60" Rear Projection Television Questions & Answers
Tv mitsubishi vs-60111
Was there a power failure? unplug unit for a min and plug it back in. hold power button til unit turns on. If it still flashes you may have a power supply problem inside the unit.
Some of my channels are only in spanish, some have no sound
Look first in the menu for the set and then in the menu for a box if used:In either place if set is set to SAP (secondary audio program) some channels will be in Spanish or have no sound.It can be the setting in the TV or a cable or sat box if used.
Vs 60111 Fuzzy picture
Its a very old set and if happens on all inputs and cables have been ruled out something serious--the rear inputs bypass the tuner in the set and based on its age I would not suggest spending major money (if you can find someone willing to work on a set of this age) on this set.Many parts for this are no longer available.
How do i get rid of purple horizontal distortion lines?
This is a older model and likely the first generation of HD set made by Mitsubishi---where the HD input is on rear (DTV?) ARE THERE TWO JACKS MARKED H sync and V sync?If they are there set needed an external box made only by Mitsubishi for for later HD use.
How much does the fuse cost
A fuse can cost a few dollars; The question is what is your set doing or not doing, I have fixed and lot of the Mitsubishi sets,.
Flashing Tv screen
Turned out to be a problem with my dish receiver. Found out by attaching a separate DVD unit to the TV, and it didn't flash. I then realized everything ran through the dish receiver. Called them, reset ( by unplugging for 90 seconds) and all was well.
