Cooktops Logo
Posted on Sep 22, 2010
We urgently need to repair the Rosieres cooktop, V48 halogene. We believe the elements need to be replaced. We are situated in Kenmore, Brisbane. Are you able to assist with this? Thanks
2 Related Answers
Anonymous
  • 93 Answers
  • Posted on Jul 21, 2008
SOURCE: Gagganau Glass Cooktop
www.foxatlanta.com
Anonymous
  • Posted on Dec 03, 2011
SOURCE: Is there any replacement for Halogen element D8598902 in Amana cooktop?
I'm looking for the same part. So far no luck. If I find a source, I'll post it here.
1helpful
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 • GE Cooktops
Replacing wires on surface element switch(kenmore cooktop)..need to know where they hook up
Usually you can copy wiring from other element. Safest to consult wiring diagram found inside control panel.
Converting natural gas to lpg
There will be a brass plug in the line where the gas comes out with a hex head and a small hole in it. You need to install a new plug with a smaller hole for lpg.
Nov 22, 2011 • Cooktops
The Halogen burner on my 36" GE profile cooktop does not work
Sorry to read about your problem, I hope this helps you out.
either the element is burned out or the control relay is defective,
I suggest you call a service company
If you live in the Denver area i can help you...
1helpful
The top of my halogen hob has cracked from top to bottom thro the centre is there any way of repairing it? it is a 5 ring creda rangemaster
you cant repair the glass but you can get the ceramic glass as a spare part. you will need the exact model number to get the correct part once done your hob looks brand new. if cracked through one of the zones you could chack there is no damage to element or themal cutout running across the centre of the element before proceeding.
Aug 22, 2010 • Cooktops
Regulating the heat on Kenmore cooktop.
Bad control or infinite switch. replace the switch for that element and you will be good to go.
Left burner is not working
these elements merely unplug when you lift up the one side of the element,then just easily rock back and forth till it unplugs from the stove top
Kenmore Stove
Check the wiring first, but it is usually the element. When they burn out t hey usually short to ground.
Top Rosieres Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Rosieres Cooktop Expert? Answer questions, earn points and help others
