I was restoring my phone on itunes and the power went out now when i try to do anything with the phone it is just stuck on the apple logo and itunes wont even identify when plugged in any advice?
To fix your iPhone stuck on Apple logo, you may try some methods below.
1. Charge your iPhone and wait for a while.
2. Hard reset your iPhone. The steps between different iPhone models are various, you can read on this tutorial to hard reset your iPhone: https://support.apple.com/guide/iphone/force-restart-iphone-iph8903c3ee6/ios
3. Restore iPhone with iTunes in recovery mode.
4. Repair your iPhone with some iOS repair software such as Leawo iOSFix.
5. Contact Apple for hardware repair if you have tried all methods above.
Read on this tutorial for more detailed steps: https://www.leawo.org/entips/what-to-do-when-iphone-is-stuck-on-apple-logo.html?fixya=1409
Seems to be a very common problem, This information from Sharp Tools should fix your problem. Let me know if you need any further help and I would be glad to do what I can. good luck
woops, sorry, misread that
This is a common problem too.
To perform a soft reset, press and hold the iPhone’s Sleep/Wake button
and the Home button for several seconds.
alright, then try doing what post #8 and #9 say to do on this link and let me know the outcome of this
http://forums.macrumors.com/showthread.p...
click on restore to original settings and see if it has the backup option there, if not, you can always reload information once it gets working and an apple store could probably get any information that you may loose.
sounds good, let me know how it goes
Once your problem is fixed, please give me some feedback by rating my solution. I will check back later on this to see how you are doing. good luck.
Were you able to fix this, if so then please give me some feedback by rating my solution. If you need any more help, I would be glad to assist you, just ask.
thanks and Have a Great Day!
Click HERE for troubleshooting instructions from Apple regarding this issue.
Did you try to reset the phone by pressing the power button and home key?
1. Do a hard reset on the phone, hold the sleep/wake button + the home
button until it turns off then release before it turns back on.
2. Plug the dock into the compute and have iTunes running.
3. HOLD the home button on the iPhone, while holding it, connect the
iPhone onto the dock and CONTINUE to hold the home button until the
CONNECT TO ITUNES DISPLAY APPEARS.
4. iTunes will recognize this and ask if you would like to restore it.
Click restore. Then choose to restore from BACKUP! This will take a few
minutes. It will fix the problem. Your iPhone will be up and running as
normal and all your contacts, sms, bookmarks, settings, etc. will be
intact. The only thing that will be erased is the music. But you can
easily add that all back right.
Please go through my solution it will fix your problem.
Its the Iphone not Ipod and it wont let me do anything its just stuck on the apple logo
theres no rewind button on the phone
thats ok i tried holding the sleep/awake button and home just goes off for a second then the apple logo comes right back and wont let me do anything else...
ok it recognized it how do i restore from backup it just says restore to original settings
ok thank you, im just waiting for it to finish restoring
