Sharp R-1480 Microwave Oven Logo
Posted on Sep 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I put a metal pan with food inside my microwave oven. I heard a popping sound and there are now two tiny black marks pitted into the glass on the door. I can feel the two pitted marks from both inside and outside the door. Is it safe to continue using the microwave oven? [email protected]
Thomas Aldrin Nullas
Level 2:
New Friend:
  • Expert 128 Answers
  • Posted on Sep 20, 2014
Expert
Level 2:
New Friend:
Answers
128
Questions
0
Helped
36483
Points
198
Dont use metal or foil .
Kelly
Level 3:
  • Sharp Master 3,740 Answers
  • Posted on Sep 21, 2010
Kelly
Sharp Master
Level 3:
Answers
3740
Questions
Helped
2163453
Points
12091
Yes it is safe to continue using the Microwave as long as the integrity of the glass is not compromised and the pitted marks do not exceed 1/4 inch. The RFwave generated by the magnetron is a pretty wide RF wave beam.
If your really concerned you can take the unit to any appliance service center and ask that they perform an RF leakage test. There is really no other way to know if your leakage is within acceptable limits. I can tell you from personal experience that the ony microwave I ever saw demonstrated excessive leakage had either been dropped and had hinge or latch damage.
If your really worried about it and can not get to a service center you can do this test:
- Wrap a tall empty glass with a sheet of aluminum foil and place it about 3 inches away from the microwave in front of the area you where noticed the pitting.
- Run the microwave with a GLASS filled with water of equal size for 1 minute.
- Stand back 3 to 4 feet and watch for any signs of a spark on the aluminum foil.
- As soon as the microwave shuts off check the dry foil wrapped glass for any signs of heat.
(No heat.... no problem. Sparks or Heat = repair time.)
Thanks for choosing FixYa.
Kelly
tip
Microwaves and how they work. ­T­he microwave oven is one of the...
Caption
--> ­T­he microwave oven is one of the great inventions of the 20th century -- millions of homes in America have one. Just think about how many times you use a microwave every day:
Caption
­You're running late for work, so there's no time to fix breakfast at home. On your way to the office, you stop to gas up your car. Inside the quickie-mart, you grab a frozen breakfast burrito and pop it in the microwave on the counter. Later that day, you have to work through lunch. By 3:00 p.m., you're starving, so you grab a snack-pa­ck of microwaveable popcorn from the vending machine and pop that in the break-room microwave. That night, after a really long day at work, you're simply too tired to grill out, so you dish up last night's lasagna and heat it up in the microwave...
As you can see, microwave ovens are popular because they cook food in an amazingly short amount of time. They are also extremely efficient in their use of electricity because a microwave oven heats only the food -- and nothing else. In this article, we'll discuss the mystery behind the magic of "meals in a minute" with microwave cooking.
­A m­icrowave oven uses microwaves to heat food. Microwaves are radio waves. In the case of microwave ovens, the commonly used radio wave frequency is roughly 2,500 megahertz (2.5 gigahertz). Radio waves in this frequency range have an interesting property: they are absorbed by water, fats and sugars. When they are absorbed they are converted directly into atomic motion -- heat. Microwaves in this frequency range have another interesting property: they are not absorbed by most plastics, glass or ceramics. Metal reflects microwaves, which is why metal pans do not work well in a microwave oven.
Microwave cooking ­You often hear that microwave ovens cook food "From the inside out." What does that mean? Here's an explanation to help make sense of microwave cooking.
Let's say you want to bake a cake in a conventional oven. Normally you would bake a cake at 350 degrees F or so, but let's say you accidentally set the oven at 600 degrees instead of 350. What is going to happen is that the outside of the cake will burn before the inside even gets warm. In a conventional oven, the heat has to migrate (by conduction) from the outside of the food toward the middle. You also have dry, hot air on the outside of the food evaporating moisture. So the outside can be crispy and brown (for example, bread forms a crust) while the inside is moist.
In microwave cooking, the radio waves penetrate the food and excite water and fat molecules pretty much evenly throughout the food. No heat has to migrate toward the interior by conduction. There is heat everywhere all at once because the molecules are all excited together. There are limits, of course. Radio waves penetrate unevenly in thick pieces of food (they don't make it all the way to the middle), and there are also "hot spots" caused by wave interference, but you get the idea. The whole heating process is different because you are "exciting atoms" rather than "conducting heat."
In a microwave oven, the air in the oven is at room temperature, so there is no way to form a crust. That is why microwavable pastries sometimes come with a little sleeve made out of foil and cardboard. You put the food in the sleeve and then microwave it. The sleeve reacts to microwave energy by becoming very hot. This exterior heat lets the crust become crispy as it would in a conventional oven.
on May 07, 2010 • Microwave Ovens
1helpful
930w /27l. How do I use easy cook?
Actually you don't need to use glass. There are some great polymers recipients or cookers to cook. They are really expensive but useful to prepare food in microwave.and come with special receipes.
Now, your best resource is to buy food prepared to be cooked in microwave. Somewhat expensive but time-saving and practical.
2answers
Kitchen aid microwave Kcms185j is arcing on the inside ceiling when popping popcorn, but normal when frying bacon?
It may be the oil in the popcorn---do you own one of the covers that go inside to cover so food does not splatter?
1helpful
Microwave popping sounds and flashing lights
The magnetron may be arcing, get warm soapy water and remove all food particals from inside of microwave oven until spotless, and check the hood for bare metal.
My microwave was making a popping sound. then while i was nuking some popcorn, i heard a loud bang. when i opened the microwave, i saw that the glass turntable plate on the inside had split into two...
What usually happens to make the plate break or shatter is heat build up in one place, caused by spillage of food stuffs that have "welded" themselves to the plate or a scratch on the plate allowing water to enter and when it gets hot explodes the plate.
There, from what you have explained and the information you have supplied, no reason to doubt the machine. A new plate and it should work again with no problem.
Hope that puts your mind at rest.
2helpful
Put A foil pan in it to warm and now has a burning smell and makes a noise, not heating. assume we blew something Sharp R-7A85
Never, never, never, never, never put anything metal in a microwave oven! No metal, no pot or pan, no silverware, no plate with metal trim ... nothing! No "Jiffy Pop" (comes in a metal container). Use ONLY microwave safe containers. Some claim there are health concerns (dangers) to using anything plastic in a microwave. The claim is the chemicals in the plastic which were not meant to be consumed are consumed as they are burned out of the plastic into the food. These chemicals are know to some to be cancer causing. I am not making this claim ... only passing on what I have heard about plastics. For myself, I don't use plastic or paper (fire hazard) in the microwave. For one thing, I don't like the taste of food that has been prepared or reheated in a microwave in a plastic container - particularly coffee.
Having said that ... here is what is going on. You probably reflected microwave back into the magnatron and ... well ... cooked it. In my area, such damage is not economically repairable. The tech wants $100.00 to look at it, magnatrons are typically $50 to $100 or more. There could also be other damaged parts ... repair bill could be more than a replacement oven.
If you find a oven that comes with a rack, here is how that works. You will observe that the rack sits with flat feet on a carousel which is typically out of the range of the microwave OR has been built to reflect the waves in a manner that they will not damage the magnatron. Typically, a rack will be made of very small round stock that will not reflect much in any single direction ... besides that, you would have food on the rack that would absorbe most of the energy anyway.
If you replace this oven, please ensure you review all the warnings and instructions that will accompaly your new oven ... even the seemingly silly stuff like "dont use the microwave in your bath tub to heat the water".
I believe your oven is cooked. I'm sorry you are having this trouble and I hope my comments have helped you to arrive at a workable solution to your problem.
Thank you for your interest in FixYa.com
If you are pleased, the courtesy of a positive vote and response will be appreciated by this volunteer effort on my part.
Sounds like cooking metal
i once had a similar problem. look at where microwaves enter the oven chamber and look for some sort of food splatter screen. possible the splatter has accumulated over time. mine was baked on so I actually boiled it out in a pan of boiling water. problem cured.
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
