SOURCE: Thomas the Tank Engine, Sodor Post Office Train Track
http://www.thomasandfriends.com/usa/news_product_info.asp
scroll down the images till you see the set that they have. click on it when the page opens look for instructions... click on that it should have them. note i did see at least one recall notice so make sure that doesn't involve the set you have
Robert
Please take a moment to rate this solution thanks
SOURCE: Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
SOURCE: Where do I put the battery for the HIT motorized Thomas train
i will try my best to help, i had the same problem with my sons as well..i was in the same situation:).You have to take the top of the train and the bottom of the train apart, seperate the top & bottom,then the battery compartment is inbetween the two..sounds confusing i know..they are very hard to pry apart.Hoped I helped!
ok I have a train the light and sound work, but the train does not move. Used alligator clips from battery direct to motor, then the motor runs. Just ordered a circuit, will post when receive circuit with sound 15.00.
SOURCE: I need the instructions to
service.mattel.com. Instructions can be downloaded. Product ref: R9634
