I just upgraded my router to v8.7r5 and after a few days, presumebly the PPOE expired, the router no longer was connected to the internet.
I tried rebooting the modem (Westel) which is in bridge mode, and the router as well several times.
What I finally found out was that I needed to manually Establish WAN Connection....
Once I did the manual connection, my connection was restored.
If I restart the router, then the wan connection is not being made.
Log:
-Date-----Time-----Event------------------------------------------------------
----------------------------------SCROLL UP-----------------------------------
05/18/08 18:47:03 PPPOE: Discovery state started
05/18/08 18:46:28 PPTP-1 down: Remote clearing
05/18/08 18:45:29 EN: IP up, WAN 1, gateway: 192.168.1.254
05/18/08 18:45:23 >>WAN: Ethernet WAN1 activated at 100000 Kbps
05/18/08 18:45:19 PPP-1 down: No Sync
05/18/08 18:45:19 IP: Demand call requested by 192.168.8.101
05/18/08 18:45:19 --Device restarted-----------------------------------------
I am thinking that I might have to default the router as some corruption might have taken place.
Anyone have any ideas before I take that action?
Lu
SOURCE: netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
SOURCE: Need nat type 2-PS3 Cable ISP digital phone modem wireless route
you can put your ps3 in a dmz zone. if still does not work its not your router. u can keep your ps3 in dmz and get your router to open ports. u can call your router company. If still does not work its not your router more than likely. It might be your modem. i have at&t and that was my issue. i went to dmz on modem and allowed it to pass through dmz zone and ip addresses to pass through. but make sure on your comp u have spyware or something. Your ps3 can not get virus.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
More of the log.
05/18/08 18:47:19 PPP: IPCP negotiated, session 2, rem: 192.168.149.11
05/18/08 18:47:19 PPP: MSCHAP-v2 remote accepted us, Channel 2
05/18/08 18:47:19 PPP: NCP up, session 2, Channel 2
05/18/08 18:47:19 PPP: Channel 2 up, Dialout
05/18/08 18:47:19 PPTP: IP up, rem: 65.12.192.210, via: 127.0.0.2
05/18/08 18:47:03 PPP: IPCP negotiated, session 1, rem: 65.14.252.17
05/18/08 18:47:03 PPP: CHAP remote accepted us, Channel 1
05/18/08 18:47:03 PPP: NCP up, session 1, Channel 1
05/18/08 18:47:03 PPP: Channel 1 up, Dialout
05/18/08 18:47:03 PPPOE: Session state started
05/18/08 18:47:03 PPPOE: PADS Received
05/18/08 18:47:03 PPPOE: PADR Sent
05/18/08 18:47:03 PPPOE: PADO Received
05/18/08 18:47:03 PPPOE: PADI Sent
