Lands Phones Logo
Posted on May 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot enter a number for quick dial. - Lands Phones
A
Anonymous
You must first store phone number.
Press "STORE" button
Enter phone number
Press memory location (M1,M2 or M3)
To place a call, pick up phone and press memory location
(M1,M2 or M3)
Anonymous
Level 3:
  • Master 667 Answers
  • Posted on May 19, 2008
Anonymous
Master
Level 3:
Answers
667
Questions
7
Helped
475569
Points
2095
Hey Dilkin - what's the make and model # of your phone please. Thanks.
Jeff
  • Anonymous May 19, 2008
    Sorry. That was only supposed to be a question, not a solution. Please don't rate this yet. Thanks.
3 Related Answers
Anonymous
  • Posted on Jan 09, 2009
SOURCE: dialing presets
Hi John, you posted this a LONG time ago.. but I will add a sollution incase anyone needs to find out in future..
to add a number (i.e 01234567890)
1. Lift the handset
2. Press the 'STORE' key, then enter 01234567890
(the number will not be physically dialed - rather, the telephone is memorising it internally)
Press the 'STORE' key again after you enter the number
then select the button you wish to locate it to.
i.e : 'STORE' » enter telephone no. » 'STORE' » Press desired memory button..
Hope this helps
Kevin (In Dublin, Ireland)
Anonymous
  • 945 Answers
  • Posted on Nov 28, 2009
SOURCE: How do you enter and delete quick dial numbers
http://phone.manualsonline.com/manuals/mfg/british_communications_bt/bt_freestyle_2100.html
Click on the above ,then download manual.
number quick dial start from pg 2.
Hope i`ve helped!
Anonymous
  • 104 Answers
  • Posted on Aug 01, 2010
SOURCE: If I enter the phone number and then press
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
1helpful
2answers
Cannot delete old quick dial numbers
quick dial numbers cannot be deleted.you just have to make sure you print first the auto dial list for you to know where it is located.go to that location,enter zeros and then menu/set to save the number as a zero
1helpful
How do I program in a fax number?
Register Fax dstinations:
  • Press User tools/counter button
  • Select System settings using the up and down arrows then press Ok
  • Select Key Operator Tools using arrows then press Ok
  • Select Address book Management using arrows then press Ok
  • Select Program/change using arrows then press Ok
  • Enter the registration number or Quick dial key, then OK
  • Enter user (destination) name using Quick dial keys - OK
  • Press Dest.
  • Press Fax settings using arrows then OK
  • Enter the fax number then press OK
The "Programmed" message appears, and then the "Address book" display returns.
Press the User Tools/Counter button.
Good luck and please rate me, thanks.
Storing numbers in speed dail for the Savin Fax 3699
1. Press "USER TOOL"
2. Press 1.
3. Press 1 again
4. Enter 01
5. Press a free Quick Dial key
6. Enter the fax number.
7. Press [Name]
8. Enter name for this Quick Dial
9. Press [OK]
10 Press [OK] again
11 Press [PrevMenu]
12 Press [PrevMenu] again
13.Press [Menu]
14.Press[Exit]
8helpful
Dialing presets
1. Lift the handset
Hope this helps
3answers
Programming a number for memory
Memory
Store up to ten 20-digit numbers in memory for quick dialing.
Storing a Number in Memory
1. Make sure the phone is OFF (not in TALK mode).
2. Press the MEMORY button.
3. Press a number (0-9) to store the dialed number in that memory location.
4. Press the MEMORY button again.
5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm.
6. To enter another number in a different memory location, return to step 1 and repeat the process.
3helpful
3answers
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
