Xact Communication XG2200 Cordless Phone Logo
Posted on Sep 12, 2010
Cannont read the display on handset - Xact Communication XG2200 Cordless Phone
DS6321 out of range, no power at base
This sounds like a registration problem, the handset(s)
and the base have lost identification with each other.
I. To address this, first de-register the handset(s) ---
do this procedure for each handset:
0. Start by taking off the battery compartment cover....
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??", press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY (why the cover was off)
9. Wait ~30 seconds, re-connect the battery & replace the cover
10. display reads "Not Registered" ===============================
II. To register the handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #1" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a few
hours and try the registration ( II ) again.
NOTE: the base can only handle 5 handsets and will
increment the number of each handset registered
until "Handset #5" has appeared, even if some of
the handsets are lost/not in use. Trying to register
more than 5 handsets will result in "Registration Failed."
III. To clear the base of all handset registrations and
be able to start registering again at Handset #1:
1. press [Find Handset] on the base and hold past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink.
2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration
3. for multiple handsets, return to II. above and
register each handset in turn.
Good luck !!
3 of my 5 phones say "No Line"?
This sounds like a registration problem, the errant
handset(s) and the base have lost identification
with each other.
NOTE: the CS6429 works a maximum of 5
handsets, so you have a "fully populated system".
You will have to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ).
( I ). First de-register each handset ---
1. press [menu]
press [select]
(this is why the cover was off)
replace the cover
( II.) To clear the base of all handset registrations
blink. 2. release the [Find Handset] button momentarily,
ready for fresh registration ===============================
( III.) To register each handset to the base:
"Handset #x" or it will say "Registration Failed".
few hours and try the registration ( III ) again.
Good luck !!
Handset display says "Connecting" I can't deregister. How can I get the handset to display "not registered"?
The procedures to deregister are, of course, specific
to each make and model number of cordless phone.
All of them are a LOT more involved than simply
removing the battery.
For some AT&T, VTech, Uniden, & GE model numbers
you might try the following:
For many AT&T models it is simple:
1. When the handset says "Connecting..."
enter *331734 [menu]
it will soon (chirp) and display "Not registered"
For many VTech models it is a bit more involved:
1. Start by taking off the battery compartment cover.
2. press [menu]
3. scroll up/down to "Settings"
4. enter * 7 8 9 0 #
5. if display reads "Test Base",
scroll to "Test Handset", press [select]
scroll to "next page", press [select]
6. scroll to "Register Clear?", press [select]
7. display asks "Confirm?" or "Register Clear??",
press [select]
8. display reads "Ok" (chirps), press [ off ]
9. UNPLUG THE HANDSET BATTERY
(this is why the cover is off)
10. Wait ~30 seconds, re-connect the battery &
replace the cover
11. display reads "Not Registered"
For many Uniden models:
1. Press and hold the [END] and [ # ] keys at the
same time, after a few seconds the display reads
2. "System Reset, Deregister Handset"
3. scroll to "... Base Unavailable"
press [SELECT]
4. Handset (chirps)
press [END]
5. display reads "Not Registered, Place in base..." =====================================
For some GE models:
1. press "program[mute]"
2. scroll to "Handset Setup" press "program[mute]"
3. scroll to "Deregistration" press "program[mute]"
4. scroll to "Yes" press "program[mute]"
5. display reads "Not Registered"
Once you have the handset displaying "Not Registered"
you can follow the User's Manual instructions to register
the handset.
The model number for your cordless phone is shown on
a small sticker underneath the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual if you need it.
Got another phone and need to program it so it will work how do I do this
First be sure the handset battery is well charged as a weak
battery will interfere with the registration process.
Then try the following ( 'works for the D1680, D1481, and similar):
( I ) Deregister the handset:
Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
( II ) Now, to re-register the handset:
Set the handset into the base cradle and wait,
after ~30 seconds the handset should display
"Handset #" and be good to go...
...or it will display "Registration Failed"
If "...Failed", try from ( I ) again.
1helpful
HandsetS #2 and #3 work properly. Handset #1 has a display screen with correct datet and time -- but no dial tone, How can I fix this?
This sounds like Handset #1 has lost its "registration" with
the base. De-registering & re-registering is often easy.
First, be sure the handset battery is well charged as a
weak battery will interfere with the registration process.
Then try this ( 'works for the D1680, D1481, & similar):
To deregister the handset:
1. Press and hold the [END] and [ # ] keys at the same time,
press [SELECT]
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
within ~30 seconds the handset should display
a "Handset #" and be good to go.
Have a replacement handset, base is cs6729-2 handset is cs6729-3 how do i set up new handset to see base?
This sounds like a registration problem, the new
handset must be de-registered from its original
base and then registered to your base.
NOTE: the CS6729 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
1. press [menu]
press [select]
replace the cover
( if needed, else skip ahead to ( III ). )
Good luck !!
Vtech cs6649 will not register more than one handset
The errant handsets must be de-registered from their
original base and then registered to your base.
NOTE: the CS6649 handles a maximum of only five
In that case, you can clear each handset ( I ) then clear
1. press [menu]
press [select]
replace the cover
Good luck !!
My phone displays out of range how to correct
This sounds like a registration problem. Try
de-registering the handset(s) and re-registering
to your base.
NOTE: the CS6429 handles a maximum of 5
1. press [menu]
press [select]
replace the cover
Good luck !!
Vtech cordless handset CS6209 will not connect with CS6229-2 base
Yes. The'old' handset must be de-registered from its
NOTE: the CS6229 handles a maximum of 5
1. press [menu]
press [select]
replace the cover
Good luck !! --
Cannont find drive 0
Your hard drive has probably crashed.
You might want to have a local tech check it out to make sure.
Top Xact Communication Lands Phones Experts
k24674
Are you a Xact Communication Lands Phone Expert? Answer questions, earn points and help others
