You will have to leave it on for a while to sync up with the satellites. Once it settles in it will always find your location quickly unless you leave it off for a long period or move it a long distance since you turned it off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/saam_2816e29ba1070532
SOURCE: My Garmin C330 doesn't seem to show any maps
Try to change the antena? what the hell does that Suppose to mean. Where am I going to get an antenna and better yet why should I change the antenna on a unit the still has warranty. The idiots at Garmin could not figure it out so how should I???
SOURCE: garmin nuvii 350-anyway to install marine charts on this unit?
No. This unit is not designed for marine use, and therefore is not designed to accept marine charts.
SOURCE: GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
SOURCE: Garmin 498 - trouble finding satellites
Push power/menu together or power/page together. the whoole unit will reset. you will lose all saved data but this may help
SOURCE: no satelite acquisition for garmin 172c
you need to go outside in an open area with no trees around and turn the garmin on untill it receives a sat connection it can take several minutes for it to find it
