20 Most Recent
Garmin Gpsmap 498, External Antenna With Dual Frequency Transom Mount Transducer Questions & Answers
Sonar is working erratically. Loses
I have a very similar problem. Unfortunately my boating season is over until next May. I found I was at software rev 2.30 and should be at 3.40 Some of the software updates were to resolve sounder problems.
My positioner arrow shows a
the blinking indicates a satelite not finding you. push the done button for that location and the Garmin should reset itself. don't start the garmin inside any garage.
kdog
Can an external antenna be added to Garmin 498
Hi
Sure you can use an external antenna.
Here it is
It is however really only useful to allow for decent veiw of satelites when the unit is monuted under a the signal shadow of a cabin or below decks. Any GPS will not perform as well if a decent shot of 3 or more satleites is not acheived. I suspect this is what is hampering your device. Using the external antenna mounted to get maximum view of the sky will eliminate any such issues for you.
Please take a moment to rate this solution. heers
regards
robotek
